z601c(at)anemicaardvark.c Guest
Posted: Tue Jan 19, 2010 9:01 am Post subject: paint removal on upgrade |
On Tuesday 19 January 2010 08:27:12 BobbyPaulk(at)comcast.net wrote:
| Quote: | List,
Has anyone devised an easy way to sand the paint around the drilled out
rivets. Also will it be better to paint just around the rivets and try to
blend the paint or sand the whole part and paint again?? If primer is used
around the sanded area it will take more coats of paint to cover and hide
the color. Any ideas?
Most of the time, aluminum isn't sand blasted, because it removes the
protective layer of aluminum at the surface of the material. The best bet is
probably paint remover. When that's done, a wooden craft stick can be used to
scrape the paint from around the rivet.
It's a tedious process, but it's better for the metal.
Whether you repaint the whole thing, or just touch it up seems to me to be a
personal call. It's probably going to look better it if it's totally stripped
and repainted. But that's a lot of work. I doubt Zenith went that far on their
demo aircraft.
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
601XL Builder
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Wed Jan 27, 2010 11:37 am Post subject: Re: paint removal on upgrade |
Jim. you're thinking of 2024 ALCLAD.
6061 of any temper (mainly T6 for us) has no protective coating....Geoff
