gkrysztopik(at)satx.rr.co Guest
Posted: Thu Apr 29, 2010 2:04 pm Post subject: front crank seal |
Anybody still here?
Has anybody solved the front crank seal problem? This is my third
leak. Last time I tried the stainless sleeve that's made for
replacement seals. I think I need to machine a new bushing.
Gary Krysztopik
ZWheelz, LLC - www.ZWheelz.com
Alamo City Electric Auto Association - www.aceaa.org
blog - http://voices.mysanantonio.com/drive_electric_san_antonio/
San Antonio, TX
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
Posted: Thu Apr 29, 2010 4:21 pm Post subject: front crank seal |
Hi Gary,
I had a leaky front crank seal and after cleaning the area thoroughly,
put a ring of 3M adhesive sealant in there all round, let it cure real
well and then fingered in
another ring to get the area covered. No leaks since! Perhaps, the
irregular motion between parts causes the leak and the adhesive flexes
enough to hold things dry.
When speaking of the front seal, I assume it's the end that your redrive
goes on, not the actual Subaru car-crank front end, right?
Posted: Thu Apr 29, 2010 6:13 pm Post subject: front crank seal |
interesting. did you put it on the seal or the groove in the spacer?
| Quote: | When speaking of the front seal, I assume it's the end that your
redrive goes on, not the actual Subaru car-crank front end, right?
yessir
