rickofudall
Posted: Mon Feb 01, 2010 1:11 pm Post subject: Beading versus Flaring |
Beading produces a smooth taper from the original tube diameter to the bead diameter and back again. When you push the hose on it stretches smoothly and evenly over the bead and returns to its size. The contact surface of the bead is large and smooth. 'The maximum size of the bead is limited by either the beading anvil or the maximum taper of the expansion screw of the tool and can be seen and measured while it is being made. Flaring leaves a hard edge that the hose is forced around immediately. Single flares crack, double flares are better but the contact edge in the hose is still narrow and capable of cutting the soft inner wall of the hose. The maximum diameter of the flare is only limited by a good guess and how much the tube alloy will stretch before cracking. The flaring tool, generally, has serrated jaws that leave concentric stress risers all the way around tube for about 1/2" from the flare.
Somebody send me the part number of Harbor Freight Tools beading tool.
Rick Girard
Posted: Mon Feb 01, 2010 1:33 pm Post subject: Beading versus Flaring |
Here is another beading tools:
http://www.pegasusautoracing.com/productdetails.asp?RecID=6684
-- Craig
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Monday, February 01, 2010 1:08 PM
Subject: Beading versus Flaring
Rick Girard
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
lucien
Posted: Mon Feb 01, 2010 1:53 pm Post subject: Re: Beading versus Flaring |
[quote="rickofudall"]Beading produces a smooth taper from the original tube diameter to the bead diameter and back again. When you push the hose on it stretches smoothly and evenly over the bead and returns to its size. The contact surface of the bead is large and smooth. 'The maximum size of the bead is limited by either the beading anvil or the maximum taper of the expansion screw�of the tool and can be seen and measured while it is being made. Flaring leaves a hard edge that the hose is forced around immediately. Single flares crack, double flares are better but the contact edge in the hose is still narrow and capable of cutting the soft inner wall of the hose. The maximum diameter of the flare is only limited by a good guess and how much the tube alloy will stretch before cracking. The flaring tool, generally, has serrated jaws that leave concentric stress risers all the way around tube for about 1/2" from the flare.
Rick Girard
Hi Rick,
Yep, I was thinking this exact same thing when I was considering the flaring idea....
I finally just decided to get the Parker tool and some tubing and just do it right myself. I've never regretted buying good tools anyway even if I don't immediately use them for more than one job........
There'll be a little trial and error to get the right lengths anyway depending on what water hose I can get locally so I'll be better off in the end with my own copy of the tool. I might have to make several tries so....
LS
_________________ LS
Titan II SS |
Thom Riddle
Posted: Tue Feb 02, 2010 6:11 am Post subject: Re: Beading versus Flaring |
Beading tool on Amazon.
http://www.amazon.com/Earls-008ERL-EZ-Beader-Tubing/dp/B000A8OTVI
No idea if it will do the job but it is a lot cheaper than $400.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
lucien
Posted: Tue Feb 02, 2010 6:46 am Post subject: Re: Beading versus Flaring |
Yeah I was considering this one too, but I couldn't get enough info on what size I needed to get to bead the tubing I'm going to use. So I just went with the Parker tool to make sure I can do the job right and not have to go back and forth trying to get the right size tool etc....
And I'll have it around so other folks can use it in case they need it etc...
LS
Titan II SS |
pwmac(at)sisna.com Guest
Posted: Tue Feb 02, 2010 7:15 am Post subject: Beading versus Flaring |
Not a deal at all
The 2" size is $400
Then are size specific just like the old Parker kit. Here is a description: - Tubing Beaders, EZ Beader, for 3/8, 1/2, 5/8, 3/4, 1, 1 1/4, 1 1/2, 1 3/4, 2 in. Tube Outside Diameter, Kit
They don't even sell 1/4" or 5/16" for fuel lines
The Bingillis book has a description for a diy tool that works for about 3/4" and larger. I made one and the results are marginal but functional.
PW
At 06:11 AM 2/2/2010, you wrote:
[quote]--> RotaxEngines-List message posted by: "Thom Riddle" <riddletr(at)gmail.com>
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x31
We refuse to believe this country, so powerful to defend its citizens abroad, is unable to protect its citizens at home.
- Ida B. Wells
[url=http://forums.matronics.com/viewtopic.php?p 84571#284571] http://forums.matronics.com/viewtopic.php?p 84571#284571[/url]
- MATRONICS WEB FORUMS -
- List Contribution Web Site -
-Matt Dralle, List Admin.
Posted: Tue Feb 02, 2010 7:23 am Post subject: Beading versus Flaring |
Not a deal at all
The 2" size is $400
PW
PS: In a pinch when I broke my 5.16" beader on steel tubing I just lightly threaded the tube end using an oversized metric die. The result was a nice rough surface to grip the hose. Used on a EFI truck 45psi max still holding after 5 years.
Best bet for a aircraft tube is find a shop with the Parker tools. Keep searching machine shops and radiator shops. All auto coolant connections are beaded.
PW
At 06:46 AM 2/2/2010, you wrote:
[quote]--> RotaxEngines-List message posted by: "lucien" <lstavenhagen(at)hotmail.com>
LS
LS
Titan II SS
[url=http://forums.matronics.com/viewtopic.php?p 84582#284582] http://forums.matronics.com/viewtopic.php?p 84582#284582[/url]
thesupe(at)hotmail.com Guest
Posted: Tue Feb 02, 2010 8:12 am Post subject: Beading versus Flaring |
I did a little checking on this also C because I had no idea what size the beader would do. I googled it and ended up finding out that a model 008 was 3/8" OD tubing C 009 was 1/2" C 010 was 5/8" C 011 was 3/4" C 012 was 1" C ect C ect. Price went up as the size got bigger. Take care C Jim Chuk
| Quote: | Subject: Re: Beading versus Flaring
Date: Tue C 2 Feb 2010 06:46:53 -0800
Yeah I was considering this one too C but I couldn't get enough info on what size I needed to get to bead the tubing I'm going to use. So I just went with the Parker tool to make sure I can do the job right and not have to go back and forth trying to get the right size tool etc....
LS
LS
Titan II SS
http://forums.matronics.com/viewtopic.php?p=284582#284582
&g=======================
Hotmail: Trusted ema1469227/direct/01/' target='_new'>Sign up now.
rickofudall
Spruce:
http://www.aircraftspruce.com/menus/to/tubing_beaders.html
[/url]Rick Girard
On Tue, Feb 2, 2010 at 8:11 AM, Thom Riddle <riddletr(at)gmail.com (riddletr(at)gmail.com)> wrote:
[quote] --> RotaxEngines-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
[url=http://www.amazon.com/Earls-008ERL-EZ-Beader-Tubing/dp/B000A8OTVI]http://www.amazon.com/Earls-008ERL-EZ-Beader-Tubing/dp/B000A8OTVI
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
- Ida B. Wells
http://forums.matronics.com/viewtopic.php?p=284571#284571
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
rampil
