ulflyer(at)verizon.net Guest
Posted: Wed Feb 03, 2010 10:49 am Post subject: Reason for use of Silk Thread |
What is the purpose of placing a piece of silk thread along with
sealant when joining the two cast halves of an aircraft engine. Is
this done on all engines or just Continental and Lycoming, what about
4-stroke Rotax.
jerb
frank.goodnight(at)att.ne Guest
Posted: Wed Feb 03, 2010 1:46 pm Post subject: Reason for use of Silk Thread |
Hi JERB<
Many years ago my favorite A&P told me , that on a good set of cases
the silk thread is all the seal needed. and with other sealant
[ permatex type ] there was a danger
that the excess that is squeezed out inside the engine MAY lodge in a
oil passage and cause serious problems. I don't know if this is the
gospel or not. However I have put
a couple of continental engines together using just #60 silk thread
and they did not leak. I think it was # 60 I remember that it looked
awfully small to me. Sorry I can't remember better
but it was a long time ago.
Frank Goodnight
Firestar2
Brownsville, TX
On Feb 3, 2010, at 1:44 PM, jerb wrote:
about 4-stroke Rotax.
jerb
rmurrill(at)cox.net Guest
Posted: Wed Feb 03, 2010 2:06 pm Post subject: Reason for use of Silk Thread |
One of the classic reasons is to assure a minimum thickness of bond
line...just like a scrim cloth in a composite bond....may be others as well.
Bob
Posted: Wed Feb 03, 2010 3:54 pm Post subject: Reason for use of Silk Thread |
Hi JERB,
I cut myself off before I was finished. I don't know if the silk
thread was used on any engines other continental , I built up a 65
and a 85 it may be that with modern chemistry, and with better machine
work the rules have changed. Don't know anything about Rotax [wish I
did]
Frank
jerb
Posted: Wed Feb 03, 2010 4:59 pm Post subject: Reason for use of Silk Thread |
That's an oldie. I did that on an 85 continental once and maybe an A65. Don't remember if it helped.
Those engines had a lot of places to leak: pushrod tubes were common. Could only re-swage them so many times.
O-ring at the tach drive will seep just enough to dirty the belly.
The low pressure developed by the puny oil pump kept a huge leak from occurring.
BB
On 3, Feb 2010, at 2:44 PM, jerb wrote:
What is the purpose of placing a piece of silk thread along with sealant when joining the two cast halves of an aircraft engine. Is this done on all engines or just Continental and Lycoming, what about 4-stroke Rotax.
jerb
Posted: Wed Feb 03, 2010 5:22 pm Post subject: Reason for use of Silk Thread |
occurring.
Bob B/Gang:
I am fortunate with my leak/ooze in that respect. I am dealing with
crankcase pressure of 3 to 5 psi in the gear box. Thank goodness it is not
the engine oil pressure or I would be dealing with about 50 psi.
1936 John Deere D, if the oil pressure needle comes off the peg, it is good
to go.
john hauck
titus, alabama
_________________ John Hauck
Titus, Alabama |
