		Ed Godfrey
				 Posted: Fri Feb 05, 2010 4:53 pm    Post subject: Rubbing issue |
				Listers,
      I am at the point where I am adjusting the aileron pushrods for
 proper length, before I finish with the wing. It seems when I move the
 aileron to the down position, I get a rubbing between the W1018 Aileron
 Pushrod and the W1013 Inboard Aileron Hing Bracket. This happens on both
 ailerons. I talked to Joe at Van's and asked him how much travel the
 aileron does, since I might be exceeding the travel when the rubbing
 starts. He said that I should have between 15° and 17° down travel. I
 measured it and I have about 9° down travel when the rubbing starts. Has
 anyone else run into this issue? I have checked to see if I might have
 had an extra washer that is moving the pushrod over, but there is only
 the one washer and the spacer on the outboard side and 1 washer on the
 inboard side
 Ed Godfrey
 40717
		ricksked(at)cox.net Guest
				 Posted: Fri Feb 05, 2010 9:30 pm    Post subject: Rubbing issue |
				Ed,
 Make sure you have all the aileron spacers washers etc on first. Also make
 sure the out board rib bracket is aligned perpendicular to the rear spar.
 If I read your post correctly it's not rubbing on the opening on the rear
 spar but on the hinge bracket itself? Is it the pushrod or the rivets? You
 may have to re clock the push rod so the manufac. Head is next to the
 bracket/hinge. At full travel I know the pushrod gets close to touching but
 not quite. 9 degrees is not much down, and granted there is not that much
 down aileron due to the differential throw. Are you using the metal angle
 template to establish neutral or do you have the flap installed to compare
 it? Double check your pushrod length and remember the stop for the down
 throw is on the opposite aileron and only comes into play when the wings are
 attached and the aircraft is rigged correctly. Just some thoughts.
 Rick S.
				 Posted: Fri Feb 05, 2010 9:41 pm    Post subject: Rubbing issue |
				yep, I had the same problem.
 This is actually common, here is a response from a while back when this came
 up.
 Many times answered before....when both wings are on the aileron stop does
 not allow the aileron to deflect far enough to hit the bracket...really,
 trust us...this question always comes up when someone reaches the point in
 the wings where they test the aileron actuation for the first time....don't
 feel bad, your not the first..I think I was, and you won't be the last.
 Pascal
 Sent: Friday, February 05, 2010 4:53 PM
 To: "RV-10 List" <rv10-list(at)matronics.com>
 Subject: Rubbing issue
  Listers,
      I am at the point where I am adjusting the aileron pushrods for proper
  length, before I finish with the wing. It seems when I move the aileron to
  the down position, I get a rubbing between the W1018 Aileron Pushrod and
  the W1013 Inboard Aileron Hing Bracket. This happens on both ailerons. I
  talked to Joe at Van's and asked him how much travel the aileron does,
  since I might be exceeding the travel when the rubbing starts. He said
  that I should have between 15° and 17° down travel. I measured it and I
  have about 9° down travel when the rubbing starts. Has anyone else run
  into this issue? I have checked to see if I might have had an extra washer
  that is moving the pushrod over, but there is only the one washer and the
  spacer on the outboard side and 1 washer on the inboard side
  Ed Godfrey
  40717
