		bob.kravis(at)gmail.com Guest
				 Posted: Fri Feb 12, 2010 4:53 am    Post subject: Attitude response to flaps |
				When you deploy flaps how does the plane respond in pitch?  Does the nose go up or down and is it negligible, modest or pronounced?  Likewise, how would you characterize what happens when flaps are retracted?I am specifically interested in the Firefly but suspect that all Kolbs are somewhat similar.
  bk
				 Posted: Fri Feb 12, 2010 5:43 am    Post subject: Attitude response to flaps |
				Bob,
 As you extend the flaps the nose will rotate down in a modest to pronounced
 manner.  As you remove the flaps the reverse is true.
 Jack B. Hart FF004
 Winchester, IN
 Date: Fri, 12 Feb 2010 07:52:07 -0500
 Subject:From: Bob Kravis <bob.kravis(at)gmail.com>
 somewhat similar.
 bk
		Richard Pike
				 Posted: Fri Feb 12, 2010 7:06 am    Post subject: Re: Attitude response to flaps |
				Flaps and ailerons affect trim the same way. Lower the flaps or ailerons, the nose goes down, raise the flaps or ailerons, the nose goes up.
 Which means, if you don't like the stick pressure that you currently have, it is easy to trim out.
 Richard Pike
 MKIII N420P (420ldPoops)
