Adding Thinned Resin To INSIDE Of Cowling...
Site Admin
PostPosted: Mon Feb 22, 2010 3:01 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Greetings fellow builders,
In the manual, Van's describes a procedure of mixing some resin 1:1 with acetone to form a thin coating for the OUTSIDE of the cowling to make a filler for the pin holes and other surface imperfections. Seems straightforward enough.
But what about the INSIDE of the cowling? That open weave seems like its going to soak up any oil and whatnot that runs out of these leaky 'ol Lycomings.
Thoughts?
RV-8 #82880 N998RV
http://www.mattsrv8.com Matt's RV-8 Building Blog
Finishing up...
