MurphyMoose-List Digest: 0 Msgs - 02/09/10
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List
JWill3638(at)aol.com
PostPosted: Wed Feb 10, 2010 1:35 pm    Post subject: MurphyMoose-List Digest: 0 Msgs - 02/09/10 Reply with quote
Hi guys, I'm doing the Weight and Balance on my Moose with an M14P and I'm getting conflicting numbers as to the C of G envelope. My manual dated 29/06/98 says FWD is 9.5 and REAR 21.36. I know this is different from the manual that's on line. My manual is not clear as to where the datum was taken but I believe it was the center of the forward spar. The later version is from the center of the main axel, but I think this has moved relative to the spar to accommodate the taller gear for prop clearance. I would like to know the numbers relative to the spar. Thanks, Jim Williams
In a message dated 2/10/2010 2:58:22 A.M. Eastern Standard Time, murphymoose-list(at)matronics.com writes:
Today's complete Murphy Moose-List Digest can also be found in either of the
of the Murphy Moose-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-02-09&Archive=MurphyMoose
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-02-09&Archive=MurphyMoose
  MurphyMoose-List Digest Archive
  Total Messages Posted Tue 02/09/10: 0
Today's Message ================================================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
- The Matronics MurphyMoose-List Email Forum -
http://www.matronics.com/Navigator?MurphyMoose-List
westcoastkitplanes(at)gma
PostPosted: Wed Feb 10, 2010 9:51 pm    Post subject: MurphyMoose-List Digest: 0 Msgs - 02/09/10 Reply with quote
Hi Jim,
Datum has been main gear or leading edge of wing ( I don't ever recall it being the spar).
Moose (SR3500)
Datum is center of main gear.
Allowable CG range = 10.8 - 20.4
Jeff
On Wed, Feb 10, 2010 at 1:34 PM, <JWill3638(at)aol.com (JWill3638(at)aol.com)> wrote:
[quote] Hi guys, I'm doing the Weight and Balance on my Moose with an M14P and I'm getting conflicting numbers as to the C of G envelope. My manual dated 29/06/98 says FWD is 9.5 and REAR 21.36. I know this is different from the manual that's on line. My manual is not clear as to where the datum was taken but I believe it was the center of the forward spar. The later version is from the center of the main axel, but I think this has moved relative to the spar to accommodate the taller gear for prop clearance. I would like to know the numbers relative to the spar. Thanks, Jim Williams
In a message dated 2/10/2010 2:58:22 A.M. Eastern Standard Time, murphymoose-list(at)matronics.com (murphymoose-list(at)matronics.com) writes:
HTML Version:
Text Version:
Today's Message ======================== Use utilities Day =======================              - MATRONICS WEB FORUMS =======================            - List Contribution Web Site sp;                         =
st" target="_blank">http://www.matronics.com/Navigator?MurphyMoose-List
tp://forums.matronics.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> MurphyMoose-List All times are GMT - 8 Hours
