kitfoxsport(at)verizon.ne Guest
Posted: Sat Feb 13, 2010 9:25 am Post subject: Coolant seepage from vent hole in engine housing |
There is a small vent hole in the rear casting housing that bolts to the motor behind water pump that is seeping a little coolant. This motor has sat around for a while. Could someone describe what I'm in for and how and what I need to replace the seal. I believe by looking at the parts book that it is called a rotary seal part number 850-945.
George
Sport Model(7+)- Rotax 914- almost, but not yet!
Roger Lee
Posted: Sat Feb 13, 2010 1:53 pm Post subject: Re: Coolant seepage from vent hole in engine housing |
Hi George,
Replace the seal and gasket. Seal 850-945 and gasket 850-981. If a Rotax sits for a long time "O" rings and seals are much more likely to leak. It is better for an engine to be started and run up to temp now and then than let it sit.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
