wildirishtime
Posted: Wed Feb 10, 2010 8:36 pm Post subject: 582 cyl head venting tube? closed? doubt it... |
On my recently acquired Kitfox 3, I decided to replace
the coolant with DexCool (who knows what it had!)
I pulled the cyl head vent tube and found that the
metal nipple where the 1/4" tube plugs on the RADIATOR
side of that vent tube is CLOSED.... it was NOT drilled into
the inside of the metal neck just below the fill cap?
Shouldn't that nipple be open to the inside of fill cap neck?
It's not an obstruction - it simply was never drilled.
I hope my question makes sense, thanks!
~Wild
Guy Buchanan
Posted: Wed Feb 10, 2010 9:00 pm Post subject: 582 cyl head venting tube? closed? doubt it... |
At 08:36 PM 2/10/2010, you wrote:
| Quote: | Shouldn't that nipple be open to the inside of fill cap neck?
Yes it should. It's used to vent any vapor accumulation in the head,
either by inadequate bleed during fill, or through boiling when hot.
Sounds like an easy fix.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sun Feb 14, 2010 12:11 pm Post subject: Re: 582 cyl head venting tube? closed? doubt it... |
Wild;
THANK YOU for your post. In preparation for test running and first flight in the spring I have recently filled my 582 with coolant. After seeing your post I checked my vent fitting and....... it was not drilled either. My filling cap unit was supplied to the previous owner by Denny in 1989 ( Model II, Ser. 483). I wonder how many others are out there that are not venting properly, or how many other have had overheat problems without knowing why. This probably only applies to Model I and II but my recommendation is... check that the fitting is indeed drilled out.
Thanks again for you observation.
Cheers
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
