riquenkelly(at)aol.com Guest
Posted: Mon Feb 15, 2010 7:01 pm Post subject: Fwd: Kitfox-List Digest: 6 Msgs - 02/11/10 |
Yes, I have removed the ground leads to the DCIs completely and manually grounded each circuit while running the engine at idle, without the prop. The problem continued. The intermittent fault seems to go away when the engine is first cranked and to return when it heats up. I tried swapping only the red (trigger) lead between the two DCIs. The problem followed. I think that means the only options are a short in the 2 inches of red wire coming from the case, a fault in the connector itself, or a fault somewhere at the flywheel. I have no idea why they would put such short leads out of the case! Once I re-terminal the red lead at the case, if I don't see success I guess I have to pull the motor and R&R the harness inside the case. Anybody see a fault in my logic?
Thanks for your guidance.
