kitfoxsport(at)verizon.ne Guest
Posted: Sat Feb 13, 2010 9:22 am Post subject: coolant from vent hole behind water pump housing? |
There is a small vent hole in the rear casting housing that bolts to the motor behind water pump that is seeping a little coolant. This motor has sat around for a while. Could someone describe what I'm in for and how and what I need to replace the seal. I believe by looking at the parts book that it is called a rotary seal part number 850-945.
George
Sport Model(7+)- Rotax 914- almost, but not yet!
kirkhull(at)kc.rr.com Guest
Posted: Sun Feb 14, 2010 2:31 pm Post subject: coolant from vent hole behind water pump housing? |
Not sure about the rotax as I fly behind a Subaru but on a Chevy that would mean it is time to change the entire water pump not just a seal
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Kitfox George
Sent: Saturday, February 13, 2010 11:18 AM
Subject: coolant from vent hole behind water pump housing?
George
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
sourdostan(at)aol.com Guest
Posted: Sun Feb 14, 2010 5:06 pm Post subject: coolant from vent hole behind water pump housing? |
M/y Rotax 912ul leaked for a few days, then stopped all on its own. Be patient for a bit and see what happens.
Stan Specht
Lakewood, Colorado
Kitfox IV Speedster
912ul 1600+ hours.
Tom Jones
Posted: Mon Feb 15, 2010 6:06 am Post subject: Re: coolant from vent hole behind water pump housing? |
Deleted: Wrong engine.
_________________ Tom Jones
Classic IV
Ellensburg, WA
Roger Lee
Posted: Mon Feb 15, 2010 4:38 pm Post subject: Re: coolant from vent hole behind water pump housing? |
The engine in question here is a rebuilt 914 and coolant is coming out the weep hole.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
lcfitt(at)sbcglobal.net Guest
Posted: Wed Feb 17, 2010 11:52 am Post subject: coolant from vent hole behind water pump housing? |
George,
This is late as I have been out of town. I had some coolant leaking from my
912 UL after about 300 hours and the guys at Rotax - I think CPS told me to
put a proportional shot of bars leak in it and that was it.
Lowell
