Thom Riddle
Posted: Thu Feb 18, 2010 6:25 pm Post subject: PSRU on a Jabiru? |
I'm curious if anyone has every attempted to mount any sort of prop speed reduction unit on any Jabiru engine. I'm not saying I want to do this, just curious to see if anyone has ever done so. If so, results and other details would be welcome.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
matronics(at)rtist.nl Guest
zeprep251(at)aol.com Guest
Posted: Fri Feb 19, 2010 4:42 am Post subject: PSRU on a Jabiru? |
Because of the billet construction method of the Jabiru crankcase,it would be pretty easy to add mount pads to it.
G.Aman
Kayberg(at)aol.com Guest
Posted: Fri Feb 19, 2010 5:23 am Post subject: PSRU on a Jabiru? |
In a message dated 2/19/2010 7:42:36 A.M. Eastern Standard Time, zeprep251(at)aol.com writes:
| Quote: | Because of the billet construction method of the Jabiru crankcase,it would be pretty easy to add mount pads to it.
G.Aman
And it should work as well as the geared Continentals....OOPS!
The problem is the engine was designed to turn 3300 MAX rpms. If you want a geared engine, get a Rotax 912 and run it at 5500 rpms.
Anybody remember the Cessna 175?
Doug Koenigsberg
avidaerobat(at)yahoo.ca Guest
Posted: Fri Feb 19, 2010 6:10 am Post subject: PSRU on a Jabiru? |
Geared continentals worked fine, it was the pilots that still wanted to run them at 2500rpm. that caused the problems.
There has been a lot of success with VW's and gear reductions. Their rpm's are similar to the Jabiru.
Slower moving propellers are more efficient. To slow can be a problem under certain circumstances.
--- On Fri, 2/19/10, Kayberg(at)aol.com <Kayberg(at)aol.com> wrote:
Subject: Re: PSRU on a Jabiru?
To: jabiruengine-list(at)matronics.com
Received: Friday, February 19, 2010, 3:49 AM
G.Aman
Doug Koenigsberg
| Quote: | | t="_blank" href="http://www.matronics.com/Navigator?JabiruEngine-List">el="nofollow" target="_blank" href="http://www.matronics.com/contribu=== |
The new Internet Explorer® 8 - Faster, safer, easier. Optimized for Yahoo! Get it Now for Free! [quote][b]
pete(at)usjabiru.com Guest
Posted: Fri Feb 19, 2010 6:44 am Post subject: PSRU on a Jabiru? |
It has been tried a few times. I've been told it resulted in a broken
crankshaft each time.
Pete
Thom Riddle
Posted: Fri Feb 19, 2010 6:48 am Post subject: Re: PSRU on a Jabiru? |
Thanks, Pete.
I was hoping you would have some knowledgeable input. Good idea on paper but looks like the crank is not up to it.
Buffalo, NY (9G0)
- Anonymous |
