		topglock(at)cox.net Guest
				 Posted: Mon Feb 15, 2010 11:35 am    Post subject: GPS antenna mounted to instrument moduleGPS antenna  mounted |
				My remote antenna is mounted on the inside of the firewall, high in the
 panel, over the left foot of P-1.  The WX antenna is inside the panel,
 on top of the radio stack.  Everything works fine...
 Jeff - Baby Blue
 Roger Mills wrote:
  	  | Quote: | 	 		   You can probably even mount it out of sight if you want   to.
  My GPS 496 antenna is mounted on an aluminium bracket on top of the
  radio stack so that the antenna surface is just below the top of the
  instrument module. It’s completely covered and still works perfectly –
  over 2 years I’ve never had any reception problems!
  Roger Mills
  Europa 141
  *Time: *
  */10:25:36 PM PST US/*
  */"Gavin & Anne" <gavanne(at)iconz.co.nz <mailto:gavanne(at)iconz.co.nz>>/*
  *Subject: *
  */_GPS antenna mounted to instrument module_/*
  *      Hi Ron*
  *      I have the Garmin 295 panel mounted and have the external aerial on top of*
  *      the instrument panel looking through the windscreen in about the centre of*
  *      the panel. Works very well and its slimline shape is not noticeable.*
  *      Cheers*
  *      Gavin Lee...ZK-EPA*
  *        _____  *
  *      From: owner-europa-list-server(at)matronics.com <mailto:owner-europa-list-server(at)matronics.com>*
  *      [mailto:owner-europa-list-server(at)matronics.com] <mailto:owner-europa-list-server(at)matronics.com]> On Behalf Of*
  *      rparigor(at)suffolk.lib.ny.us <mailto:rparigor(at)suffolk.lib.ny.us>*
  *      Sent: Tuesday, 9 February 2010 7:58 a.m.*
  *      Subject: GPS antenna mounted to instrument module*
  *      Hi group. *
  *      We are working on instrument module at moment.*
  *      We have a Garmin 295 and was wondering if anyone has mounted the antenna to*
  *      the underside of the top of the instrument module just about above the gear*
  *      lever cutout?*
  *      Bout how far aft of firewall?*
  *      Any input would be appreciared.*
  *      Ron Parigoris *
  Checked by AVG - www.avg.com
