bob.kravis(at)gmail.com Guest
Posted: Sat Feb 20, 2010 2:19 pm Post subject: 447 fuel pressure sensor |
The new FF has a GRT 2002 EIS with altitude sensor. Hal said it is sweet. I looked at Grand Rapids website and saw that they offer a fuel pressure sensor. As I have read in the postings, many of the engine outs are due to fuel starvation. There is a testimonial on their website (see Flying Impressions) about an RV owner who turned back when he got a low fuel pressure warning after takeoff. That got me thinking about adding one. What does the group think about that idea? Bob
lucien
Posted: Sun Feb 21, 2010 6:59 am Post subject: Re: 447 fuel pressure sensor |
| bob.kravis(at)gmail.com wrote: | The new FF has a GRT 2002 EIS with altitude sensor. �Hal said it is sweet. �I looked at Grand Rapids website and saw that they offer a fuel pressure sensor. �As I have read in the postings, many of the engine outs are due to fuel starvation. �There is a testimonial on their website (see Flying Impressions) about an RV owner who turned back when he got a low fuel pressure warning after takeoff. �That got me thinking about adding one. �What does the group think about that idea? Bob
Most of those cautions are probably just warnings against running out of gas....
Besides that, the #1 cause bar none other of fuel starvation events on the Rotax 2-strokes that use the pneumatic fuel pumps, tho, is too long of a pulse line. This is so treacherous because the mistake is so easy and non-intuitive to make. I.e. mounting the fuel pump a long ways from the engine looks pretty but leads to this problem. The line has to be a foot or less in length to properly drive the pump and preferably as short as possible.
No idea on the fuel pressure sensor as I've never used one. But the EIS you'll love (I had one on my 503-equipped FS II)....
LS
_________________ LS
Titan II SS |
Posted: Sun Feb 21, 2010 7:35 am Post subject: 447 fuel pressure sensor |
possible.
LS
Folks:
We don't have a problem with excessive length of Mikuni fuel pump pulse
lines on Kolb aircraft unless the builder makes drastic changes in
recommended fuel pump location during engine installation. Normally, there
is no reason to change locations. Most Kolb builders try to build as
cheaply as possibly. Short fuel and pulse lines appeals to those of us that
have built Kolbs.
john hauck
_________________ John Hauck
Titus, Alabama |
lucien
Posted: Sun Feb 21, 2010 7:41 am Post subject: Re: 447 fuel pressure sensor |
| John Hauck wrote: |
have built Kolbs.
john hauck
Titus, Alabama |
Regardless, if the OP needs to know what that length limitation is on the pulse line, i.e. how to recognize an installation where this mistake _has_ been made, it's about a foot maximum.
You can verify this with any Rotax dealer or mechanic, or anyone who's familiar with 2-stroke installations using the pneumatic pump.
LS
Titan II SS |
Posted: Sun Feb 21, 2010 8:04 am Post subject: 447 fuel pressure sensor |
LS
Lucien/Folks:
I don't need to verify the specs. I read the book and have been building
and flying Kolbs for 26 years.
Most of us builders get by with much less pulse tubing than one foot.
I like to rely on the operators manual for that particular engine and the
other publications that are readily available on line from Rotax for free.
In the beginning, we had only the operators manual that came with the
engine. Information from Rotax was nil. Most of what we learned we learned
from failures and by mistakes. I met Gerry Olenik in 1986. He was a
tremendous source of info for me and two stroke Rotax engines back then and
now. Homer, in 1987, would not sell me a 447 with my FS kit because he felt
the engine was too much for the FS. The 447 was the engine that powered the
Twinstar two place. I got my engine from Homer, called Gerry and horse
traded for a new 447. Times change. Three years later Homer agreed to buy
me a 503 to power my FS for a true circumnavigation of the Continental US.
The year, 1990, that I had planned the flight was the year I pulled the
wings off my FS powered with the 447. Glad I never had a chance to fly the
original FS with a 503. Although Homer changed his mind about max power on
the FS for me, I think he got that one wrong. However, his decision to give
me the 503 was an individual decision for me and not intended for the
remaining original FS fleet.
Flown in the normal category, a 503 powered original FS would have lasted as
long as a 377 powered FS. I would never have flown it like a little old
lady. With that extra power, I would have enjoyed every one of those Rotax
ponies.
john hauck
Titus, Alabama |
brett(at)xtc-paragliding. Guest
Posted: Sun Feb 21, 2010 8:14 am Post subject: 447 fuel pressure sensor |
Hi
I'm new to this list but I see it is fairly active.
I'm a Kolb Twinstar III Classic owner. UK registered, but based in
Slovenia most of the time. (G-MYIK)
I'm looking to source two replacement fuel tanks. I currently have the
20 litre tanks fitted, but want to increase the size to 25 litre tanks
(sorry to quote European standards, but if I quoted gallons we'd get all
confused between US and Imperial gallons). Does anyone know a stockist?
Preferably in Europe, but in the States otherwise and I can get them
shipped over. Dimensions are 250mm x 250mm for width and depth.
I've tried the UK importer but several emails and a couple of
conversations have resulted in no help. They don't seem to be very good
with backup. The manufacturer has also not replied to past emails. Doh.
Shame really because the aircraft it great. It's just support that seems
to be lacking whenever I need it!
Brett
www.xTc-Paragliding.com
lucien
Posted: Sun Feb 21, 2010 8:21 am Post subject: Re: 447 fuel pressure sensor |
| John Hauck wrote: |
Lucien/Folks:
Actually, it sounds like you probably do need to verify this specification. I'm talking about _maximum_ pulse line lengths, not minimum. The shorter the better on the pulse line indeed, but obeying the _max_ length is a critical safety issue. Not everyone who's built a Kolb followed the directions and being able to recognize an improper installation is crucial for safety.
Putting it another way, it doesn't matter, ultimately, if the manufacturer directed this or that particular installation of the fuel pump. The critical issue is whether the builder _actually did_ follow those directions and obeyed the pulse line length limitations or not.
An owner-op needs to know what that limitation is in order to be prepared for that contingency.
To verify, I'd suggest Ronnie Smith and/or Mark Smith (at Tri-State Kite sales) as the two best sources in the field for this information. They'll tell you about a foot, maybe a foot and a half (and I can personally vouch for the length limit myself).
LS
Titan II SS |
lcottrell
Posted: Sun Feb 21, 2010 8:47 am Post subject: 447 fuel pressure sensor |
Actually, it sounds like you probably do need to verify this specification. I'm talking about _maximum_ pulse line lengths, not minimum. The shorter the better on the pulse line indeed, but obeying the _max_ length is a critical safety issue. Not everyone who's built a Kolb followed the directions and being able recognize an improper installation is crucial for safety.
To verify, I'd suggest Ronnie Smith and/or Mark Smith (at Tri-State Kite sales) as the two best sources in the field for this information (and I can personally vouch for the length limit myself).
LS
LS
Titan II SS
WTF are you talking about? I have read the above at least twice and don't understand the argument, or the reason for one. To the best of my recollection every instruction I have ever seen say to keep the pulse line under one foot. I have never heard anyone recommend putting your pulse pump any where but as close to the engine as possible. "The shorter the better on the pulse line indeed, but obeying the _max_ length is a critical safety issue. " ????????????????? I like to have the last word as much as anyone, but it means much more if it is actually correct.
Still cranky!
Larry
Posted: Sun Feb 21, 2010 8:49 am Post subject: 447 fuel pressure sensor |
John Hauck wrote:
Lucien/Folks:
LS
Lucien/Gang:
I thought I explained that in this sentence:
| Quote: | Most of us builders get by with much less pulse tubing than one foot.
To me, that means we use less than the maximum recommended of 12" or 1'.
Must have missed something somewhere.
I repeat. I do not doubt your word about the maximum length of the Mikuni
fuel pump pulse line of 12".
Nor do I need to verify with Ronnie Smith, who is a close friend, or Mark
Smith who I do not know.
I am no disputing the length of the pulse line.
Sorry about that.
Decided to take a look at the Rotax Two Stroke Installation Manual before I
fired this response back to the Kolb List.
Sure enough, on page 15-1, it states the maxium length of the pulse line is
20". I made a mistake. Pays to look in the book, even though I have always
cut my pulse lines much shorter than 20".
john hauck
Titus, Alabama |
lucien
Posted: Sun Feb 21, 2010 9:06 am Post subject: Re: 447 fuel pressure sensor |
| John Hauck wrote: |
john hauck
Titus, Alabama |
There you go, so much for "I don't need to verify the spec" right? That's what it says in my inst. manual as well.....
Shorter than that isn't a mistake, BTW, and actually stlll improves the actuation of the pump.
FWIW, back in TX I knew a fellow who had a 447 in a Starlight. the recommended location of the fuel pump was on the firewall behind the engine, resulting in a pulse line length of more than 2'. I don't think he ever had a safe flight in the plane the whole time he flew it and had engine bogging virtually every time he went up.
The Kolb recommended installation for the FS II I had was well within this specification. I never had trouble with mine as a result.
LS
Titan II SS |
Dana
Posted: Sun Feb 21, 2010 4:55 pm Post subject: 447 fuel pressure sensor |
At 05:14 PM 2/20/2010, Bob Kravis wrote:
| Quote: | | The new FF has a GRT 2002 EIS with altitude sensor. Hal said it is sweet. I looked at Grand Rapids website and saw that they offer a fuel pressure sensor. As I have read in the postings, many of the engine outs are due to fuel starvation. There is a testimonial on their website (see Flying Impressions) about an RV owner who turned back when he got a low fuel pressure warning after takeoff. That got me thinking about adding one. What does the group think about that idea? |
I have a simple mechanical pressure gauge on my plane. Never had a problem with the pump, but it's nice to glance at it from time to time and see that it's in the normal range (3-5 psi). It's also a check on the float needle; if the pressure holds for awhile after shutting down the engine your needle/seat are still good.
-Dana
Always keep clothes and weapons where you can find them in the dark. [quote][b]
Dana
Posted: Sun Feb 21, 2010 5:11 pm Post subject: 447 fuel pressure sensor |
At 10:23 AM 2/21/2010, John Hauck wrote:
| Quote: | --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com>
pulse line... |
I always assumed the #1 cause of fuel starvation events was too much air in the fuel tank...
-Dana
Posted: Sun Feb 21, 2010 5:22 pm Post subject: 447 fuel pressure sensor |
Dana:
Please give credit to the individual that wrote the post.
I did not write it, and don't want to be associated with it.
Sounds like something Lucien would generate.
" Besides that, the #1 cause bar none other of fuel starvation events on the
pulse line..."
john hauck
-Dana
Titus, Alabama |
Dana
Posted: Sun Feb 21, 2010 5:55 pm Post subject: 447 fuel pressure sensor |
At 08:22 PM 2/21/2010, John Hauck wrote:
| Quote: | Dana:
" Besides that, the #1 cause bar none other of fuel starvation events..." |
Sorry, my mistake. It was indeed Lucien's statement; I clicked "reply" to the wrong message. In your message it wasn't automatically marked as quoted text, so I misread it.
-Dana
If at first you don't succeed, skydiving is not for you. [quote][b]
