		brubakermal(at)yahoo.com Guest
				 Posted: Fri Feb 19, 2010 10:34 am    Post subject: wheel toe and the math |
				converting angle of degrees from the number of inchees the tow in i have over a six foot measurement ????  no wonder people just guess
 Malcolm Brubaker
 Michigan Sport
 Pilot Repair
 LSRM-A, PPC, WS
 (989)513-3022
 --- On Fri, 2/19/10, Noel Loveys <noelloveys(at)yahoo.ca> wrote:
 Subject: RE: re: wheel tracking
 Date: Friday, February 19, 2010, 2:18 PM
 Whether you want toe in or toe out depends on whether you have conventional gear or tricycle gear.
 On conventional gear toe in will make the plane very squirrely while landing.  If the tail goes one side or other on landing the main gear will swerve the opposite direction this can lead to a ground loop.
 On tricycle gear toe in is not really necessary as the CG of the plane tends to keep things straight.  However some planes do have a little toe in to help assist in keeping the plane straight.
 Either way toe in or toe out the shift from straight is usually about 1 degree max.
 If you are worried about your bungee gear  not being able to handle a little toe out then you better stay away from grass strips where it will get far more workout.  These are very light planes and if your tires are wearing on the outside it sounds to me like you have way too much toe in.
 My plane a model III-A ( That is what it was sold as by Denney) The toe in can only be changes by de-tempering the welds of the legs, using brute force, then re-tempering the joints.  If your axel stub is bolted to the leg/s then I assume you do have a spring leg.
 Noel
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of PMorel
 Sent: February 18, 2010 12:45 PM
 To: brubakermal(at)yahoo.com; kitfox-list(at)matronics.com
 Subject: Kitfox-List: re: wheel tracking
 Malcolm
 Before you consider attempting to change the tracking of your wheels, consider this.  What I'm talking about is the gear leg that uses bungee cords and not the grove gear.  With bungee cords, the gear is toe in to keep the bungee cords from extending and wheels spreading outward during taxi and take-off.  Naturally, if the wheels were toe out, then the gears would want to spread out and the bungee cords would stretch.  The perfect scenario would be to have a straight track, but even with that, I think you may be looking for a potential problem.  You need to decide if replacement of the tires and expense outweighs the possibility of bungee cord breaking and more expensive damage and repairs.
 Paul Morel
 Model IV Speedster
 Locust Grove GA
  	  | Quote: | 	 		  |     http://www.matronics.com/Navigator?Kitfox-List   | 	  0123456789
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Fri Feb 19, 2010 11:09 am    Post subject: wheel toe and the math |
				You’re right... I did the math and while I didn’t come up with Lowell’s answer, it was close enough for government work  ,  the difference was 0.01 degree.
 Noel
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Malcolm Brubaker
  Sent: February 19, 2010 2:55 PM
  Subject: wheel toe and the math
    Malcolm Brubaker
    Michigan Sport
    Pilot Repair
    LSRM-A, PPC, WS
    (989)513-3022
 Noel
    Subject: re: wheel tracking
 Malcolm
 Paul   Morel
 Model   IV Speedster
 Locust   Grove GA
     	  | Quote: | 	 		  |     http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution    el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-Listet=_blank>http://forums.matronics.com   | 	  0
    123456789 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  0 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  1 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  2 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  3 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  4 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  5 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  6 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  7 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  8 	  | Quote: | 	 		  | http://www.matronics.com/Navigator?Kitfox-List | 	  9 	  | Quote: | 	 		  | http://forums.matronics.com | 	  0
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
