Recommended Letter-writing campaign, follow-up
pchap(at)primus.ca
PostPosted: Sat Feb 06, 2010 5:22 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
As for the 601XL maneuvering speed issue:
Yes some pilots may not be so aware of it.
But if that were a significant part of the breakup issue, as with
other things, one would think other planes might have problems too.
Any slow landing but slightly slippery plane -- like many of the
European LSA designs -- might have the maneuvering speed issue.
If max G is 4, the any plane able to fly more than twice its stall
speed (flaps up) will be able to fly past maneuvering speed.
(2.1 times for a 4.5 g airplane).
(All this is at gross, with the maneuvering speed reducing if under gross.)
Just pointing out a sometimes forgotten aspect of maneuvering speed.
One also does wonder to what degree the stick forces really are any
lighter than for other light planes. And whether the XL tends to
operate closer to the aft end of the CG envelope than other aircraft,
increasing how common it is to have light stick forces. But that's
just musing from someone who doesn't know the aircraft well.
It's all part of the idea that the XL does have some caveats for
flying it where an unaware pilot could break it, yet one wonders why
it hasn't happened to other light planes that might have similar
characteristics.
Peter Chapman
Toronto, ON 601 HDS / 912 / C-GZDC
daveaustin2(at)primus.ca
PostPosted: Sat Feb 06, 2010 7:48 pm    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Has enyone correlated the installed engines in the 601 HD and HDS versus the
engines in the XL? I get the feeling that XLs generally are higher powered.
Could that be a factor in the crashes?
Dave Austin
larry(at)macsmachine.com
PostPosted: Sun Feb 07, 2010 7:08 am    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Dave,
Most of the XL engines are Rotax, Corvair and 0-200s, which is not
different from the ones used in HD series.
They fly a bit faster with the thin wing, but that's about it.
versus the engines in the XL? I get the feeling that XLs generally
are higher powered.
Dave Austin
s.clive.richards(at)homec
PostPosted: Sun Feb 21, 2010 5:04 am    Post subject: Recommended Letter-writing campaign, follow-up Reply with quote
Testing e mail I tried to send earlier Mat has now unblocked me
Clive
