MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Thu Feb 18, 2010 8:10 pm Post subject: Fuel flow transducer |
Using a Grand Rapids EIS, with the red cube fuel transducer. The instructions recommend installing it after the pump, but Im planning on installing the pump on my firewall... Why cant I install my transducer in the cockpit between the gascolator and the firewall penetration? Space on my firewall is running low and as much as I don't like adding fittings in the cockpit, I don't like the transducer anywhere near the muffler since it will be difficult to firesleeve.
Thoughts???
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
jerryvmd
Posted: Fri Feb 19, 2010 1:20 pm Post subject: Fuel flow transducer |
I have an HD with Jabiru and Grand Rapids. My gascolator is on the lower
right engine side of the firewall. Have never had a vapor lock problem
there. I installed the flow sensor between the fuel filter (after the
gascolator) and the engine. I then mounted the sensor to an engine
mount strut. Readings are normal, no interference with fuel flow and the
fuel line is going ito the carb anyways.
Jerry
mtherr(at)yahoo.com Guest
Posted: Sat Feb 20, 2010 4:59 am Post subject: Fuel flow transducer |
Interesting that you did not use the transducer from Grand Rapid. Is the fuel flow software already included in the basic EIS or is it an option that comes with the transducer?
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://pages.infinit.net/mthobby
--- On Thu, 2/18/10, MHerder <michaelherder(at)beckgroup.com> wrote:
Quote: | From: MHerder <michaelherder(at)beckgroup.com>
Subject: Fuel flow transducer
Received: Thursday, February 18, 2010, 11:10 PM
"MHerder" <michaelherder(at)beckgroup.com>
transducer.� The instructions recommend installing it
firewall...� Why cant I install my transducer in the
penetration?� Space on my firewall is running low and
Thoughts???
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=287120#287120
Email Forum -
FAQ,
���- MATRONICS WEB FORUMS -
List Contribution Web Site -
� � � � � � � -Matt
Dralle, List Admin.
__________________________________________________________________
The new Internet Explorer� 8 - Faster, safer, easier. Optimized for Yahoo! Get it Now for Free! at http://downloads.yahoo.com/ca/internetexplorer/
