Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Tue Feb 16, 2010 1:41 pm Post subject: Power wiring |
Anybody have a pic or a good description of their routing of the alternator and starter wire around the engine. I am getting to the FWF wiring point and rather than reinvent the wheel I would like to see what others have done and see what works best for me. Really any FWF pics of wire runs would be nice but I don't want to be greedy. If you don't want to post or they are too big you can email them to scout019(at)msn.com. Thanks.
Eric Kallio
mauledriver(at)nc.rr.com Guest
Posted: Tue Feb 16, 2010 7:38 pm Post subject: Power wiring |
I followed the examples shown in the Vans wiring kit... But didn't get the kit. Very good starting point for all wiring.
-- Sent from my Palm Pre
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=286692#286692
n223rv(at)wolflakeairport Guest
Posted: Wed Feb 17, 2010 4:54 am Post subject: Power wiring |
I routed my alternator wire down below the #1,3,5 cylinders along the
slpit line of the case and oil pan. I used some adel clamps and stand-
offs as required. I did the same thing for the starter wires on the
other side. I can send pictures tonight if you'd like them...
-Mike
On Feb 16, 2010, at 4:41 PM, "Eric_Kallio" <scout019(at)msn.com> wrote:
Eric Kallio
Eric_Kallio
Posted: Wed Feb 17, 2010 4:57 am Post subject: Re: Power wiring |
I have to OP-37 directions as well, but often folks find a better mousetrap, and with the uniqueness of each airplane comes a different way to things. Just trying to see what else has worked for builders out there,
Eric
johngoodman
Posted: Thu Feb 18, 2010 7:11 am Post subject: Re: Power wiring |
I'm routing the #2 straight to the starter contactor, then a #4 welding wire to the "safe" side of an ANL style fuse. I will put another wire on the "safe" side for the main bus and the Alternator will be on the other side of the ANL. I could have taken the main bus from the contactor, but I wanted the wire to be on the starboard side.
In short, I am isolating the Alternator via an ANL.
John
_________________ #40572 Phase One complete in 2011 |
