Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Thu Feb 18, 2010 10:33 am Post subject: Rotax spark plugs |
How about we leave at noon?
Vic Baker
S7 912S Warp
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Fox5flyer Guest
Posted: Thu Feb 18, 2010 12:32 pm Post subject: Rotax spark plugs |
Try Ebay, Vic. I bought a pretty good sized tube for only a few bucks. I
use it in plumbing quite often for things like attaching thermo discs to
metal objects like water heaters etc.
Noon is fine with me...
Deke
Lynn Matteson
Posted: Thu Feb 18, 2010 1:15 pm Post subject: Rotax spark plugs |
It's after noon, so you guys probably left without me, as I was at
Radio Shack buying some silicone heat sink compound for a few
dollars...NOT $158. Those Rotax people gotta be out of their minds!
Lynn Matteson
Jabiru 2200, #2062, 855 hrs (since 3-27-2006)
Countdown to 1000 hrs~145 to go(157 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Feb 18, 2010, at 3:26 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
bucks. I use it in plumbing quite often for things like attaching
thermo discs to metal objects like water heaters etc.
Deke
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Vic Baker
Posted: Thu Feb 18, 2010 1:54 pm Post subject: Rotax spark plugs |
Oops, that "noon" message went to the wrong place ..... coming up on 100
hours now, going to need plugs and that "silicon heat conductivity paste".
Radio Shack eh?
Vic Baker
S7 912S Warp
Carson City, Nv
Series 7
Lynn Matteson
Posted: Thu Feb 18, 2010 5:56 pm Post subject: Rotax spark plugs |
Reading off the tube: "Silicone-Base Heat Sink Compound 0.23 Oz,
Heat conductive-helps transfer heat from component to heat sink or
chassis." part #276-1372A
This is the stuff that Polyfiber calls for (or similar) to calibrate
your iron before using it to shrink the fabric. It just conducts
heat, plain and simple. Of course, if Rotax finds out you used the
wrong stuff, phone calls to lawyers will follow. : )
Lynn Matteson
On Feb 18, 2010, at 4:53 PM, Vic Baker wrote:
on 100 hours now, going to need plugs and that "silicon heat
conductivity paste". Radio Shack eh?
Vic Baker
N369LM |
lcfitt(at)sbcglobal.net Guest
Posted: Thu Feb 18, 2010 9:33 pm Post subject: Rotax spark plugs |
Hey Lynn,
I don't think I would use a silicone based anything on an instrument that
would be used on a surface soon to receive a coat of paint. Are you sure?
Lowell
Lynn Matteson
Posted: Fri Feb 19, 2010 2:58 am Post subject: Rotax spark plugs |
For calibrating the iron used in covering a plane with Polyfiber,
they have you squirt a blob of silicone-based heat sink compound on
the bottom of your iron, then lay their thermometer into the compound
and cover with a 1/2" thick stack of paper towels. Then turn the iron
on and calibrate/ record what the thermometer says for various
locations of the irons' dial.
They also point out to be SURE to get all the silicone off the iron
before using it to shrink the fabric. It's all there in the
instruction book....yeah, I'm sure. : )
Lynn Matteson
On Feb 19, 2010, at 12:29 AM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Hey Lynn,
instrument that would be used on a surface soon to receive a coat
Lowell
N369LM |
Posted: Fri Feb 19, 2010 7:52 am Post subject: Rotax spark plugs |
Lynn,
You are spot on. I just checked my manual. That said, I still think I
would avoid any possibity of silicone contaminant on a paintable surface.
The electronics tech guy at Kitplanes suggested a possible replacement for
the silicone stuff - the white goo painted on sunburn sensitive noses. The
Zinc Oxide is the heat transfer agent in both. What I did is drill a hole
in a piece of aluminum and glued the thermometer bulb in it with some epoxy
moxed with some aluminum grindings in it. Put this on a towel face up and
rest the iron on that and the broad contact between aluminum pad and iron
bottom gives very good heat transfer.
Lowell
Float Flyr
Posted: Fri Feb 19, 2010 10:34 am Post subject: Rotax spark plugs |
Years ago when I ran a production photo lab we used heat transfer data
printing on the back of our prints and the temperature of the print head had
to be exact. Too hot and the coating on the paper would blister or burn,
too cool and the print medium wouldn't transfer to the paper. The system I
used was a series of wax pencils that would melt at specific temperatures.
Simply mark the iron with say the 285F pencil the 300F pencil and the 315F
pencil and when the first two marks melted and the third one didn't you were
right at 300F.. Using that technique you can quickly locate any hot spots
on your iron as well as quickly calibrate the iron. The two advantages are
you can quickly test the iron and clean up is just a wipe with a paper
towel.
If you want I'll dig out the pencils and get a brand name for you.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Fri Feb 19, 2010 10:53 am Post subject: Rotax spark plugs |
Good idea Lowell. I don't know why Polyfiber does it their way, but I
didn't find the silicone very hard to remove on either iron....yup, I
dropped one. : )
I just came home from a lake landing across the road....put a couple
of logs on the fire, and I'm off again....ya can't beat wheel-skis
for havin' fun!
Lynn Matteson
Jabiru 2200, #2062, 856.8 hrs (since 3-27-2006)
Countdown to 1000 hrs~143 to go(156 days to go)
Lynn,
think I would avoid any possibity of silicone contaminant on a
paintable surface.
replacement for the silicone stuff - the white goo painted on
sunburn sensitive noses. The Zinc Oxide is the heat transfer agent
in both. What I did is drill a hole in a piece of aluminum and
glued the thermometer bulb in it with some epoxy moxed with some
aluminum grindings in it. Put this on a towel face up and rest the
Lowell
N369LM |
Lynn Matteson
Posted: Fri Feb 19, 2010 10:54 am Post subject: Rotax spark plugs |
Was it Temp-a-cil? or something like that, Noel? I saw them at the
welding store.
Lynn Matteson
head had
burn,
system I
temperatures.
the 315F
you were
hot spots
advantages are
towel.
Noel
N369LM |
Float Flyr
Posted: Fri Feb 19, 2010 11:11 am Post subject: Rotax spark plugs |
I'll check for you the next time I'm in the garage... They're in my tool
chest.
They are deadly accurate and come in several temperature indicators.
Noel
Kitfox III-A
Lynn Matteson
Posted: Fri Feb 19, 2010 1:08 pm Post subject: Rotax spark plugs |
The good folks at an aviation engine repair near here use them to
determine when the cylinder heads are at the correct temp for
installing valve guides, seats, etc.
Lynn Matteson
On Feb 19, 2010, at 2:10 PM, Noel Loveys wrote:
my tool
chest.
Noel
N369LM |
