rcmutz(at)msn.com Guest
Posted: Sun Feb 21, 2010 7:34 am Post subject: Pannel |
Gary,
Nice pannel in the Cheetah. I had your overlay powder coated in almost the same color and texture. Looks good with the new glareshield I also installed.
How much do you charge for the drilled yokes?
Richard Mutzman
N399RM
Dayton, OH (Home of AYA 2010)
Hotmail: Trustedo/201469227/direct/01/' target='_new'>Sign up now. [quote][b]
GrummanDude
Posted: Sun Feb 21, 2010 11:58 am Post subject: Pannel |
To drill your yokes: about $30 to $50. It's all in the setup time. I have a jig and for the most part, it works first time out. Drilling a long hole sometimes causes the drill bit to wander off.
Prepping the yoke: Stripping and sand blasting the yokes takes about an hour, $90.
Powder coating: This can be a little as $65 for both or as much as $125. It depends on how much of a hurry you want them and whether the powder coater has to stop and clean the gun for your special color.
Wiring: The switches run about $10 each ($20 total) and the installation takes about an hour ($90) including the wiring and drilling the shafts and the back of the yoke.
So, all together, with your yokes, about $295 to $375. Generally, the yokes are in the $300 to $375 range. I have some yokes that need to be stripped and sand blasted if you don't want to wait. I would need yours in exchange.
You can save me a lot of time and you a lot of money if you strip and bead blast the yokes.
I know that sounds like a lot of money, and it is. It's just very time consuming to get it right.
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
