kevinmarie(at)blueyonder. Guest
Posted: Mon Feb 22, 2010 10:13 am Post subject: Europa parts |
Hi
I ordered a pair of throttle cables for my Europa Tri gear from Europa (UK) nearly 1 month ago!!!!
I am still waiting for them is anyone else having supply problems.
Kevin
G-ODJG
mau11(at)free.fr Guest
Posted: Mon Feb 22, 2010 3:22 pm Post subject: Europa parts |
You have another best solution :
Use a stainless steel piano wire diameter 1.5 mm, you add a graphite grease into the sleeve and it is cheaper and better than cables.
I use that 10 years ago and it is perfect no cables problems.
22-02-2010
mau11
De : Kevin Challis
Date/heure : 22-02-2010 19:19:40
A : europa-list(at)matronics.com
Cc :
Sujet : Europa parts
Hi
Kevin
G-ODJG
Jeff(at)rmmm.net Guest
Posted: Mon Feb 22, 2010 3:55 pm Post subject: Europa parts |
I've been thinking of replacing my cables with the piano wire you speak of. Do you have any pictures or can you tell me how you connected to the throttle handle and to the carb lever?
Jeff R. N128LJ Gold Rush
On Feb 22, 2010, at 4:49 PM, mau11 wrote:
| Quote: | You have another best solution :
22-02-2010
mau11
De : Kevin Challis
A : europa-list(at)matronics.com (europa-list(at)matronics.com)
Cc :
Hi
Kevin
G-ODJG
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Europa-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
rlborger(at)mac.com Guest
Posted: Mon Feb 22, 2010 5:21 pm Post subject: Europa parts |
Jeff,
I replaced my throttle cable with teflon coated SS solid wire last year when the stranded stuff kinked in the throttle box. You can see what I did in Year #8 Q3 2009 of my build web site (url in signature block).
The wire was purchased from McMaster-Carr. There is a picture of the stock labels on the page. The rest of the stuff is from ACS.
It seems to be working well for me so far.
Needless to say, you are on your own and your mileage may vary.
Good luck.
Now, if I can only get the Rotax part of the annual completed and the new brake master installed.
Check six,
Bob Borger
http://www.europaowners.org/N914XL
Europa XS, Short Wing, Intercooled Rotax 914
rlborger(at)mac.com (rlborger(at)mac.com)
Cel: 817-992-1117
On Feb 22, 2010, at 5:51 PM, JEFF ROBERTS wrote:
22-02-2010
mau11
De : Kevin Challis
Cc :
Hi
Kevin
G-ODJG
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
bmoorhouse
Joined: 29 Apr 2009 Posts: 12 Location: SW England - Somerset to be precise
Posted: Tue Feb 23, 2010 4:28 am Post subject: Re: Europa parts |
[quote="kevinmarie(at)blueyonder."]Hi
Kevin
G-ODJG
Yes - I ordered quite a few bits before Christmas - most arrived on time (but they sent the wrong springs) except for 8 brake pads & rivets (I ordered two complete sets - 4 for me and 4 for a friend with a Europa) and the die set. After many excuses the brake pads arrived about 2 weeks ago - instead of 8 they sent 6 - no die set. Eventually the extra 2 arrived plus the die set a week later.
Total of 5 telephone calls and two emails - they were very apologetic and put it down to a reorganization of the spares dept and problems with suppliers.
They debited my card for everything before Christmas - I am not a happy bunny.
_________________ _______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL |
Ivor Phillips
Posted: Tue Feb 23, 2010 10:35 am Post subject: Europa parts |
On the other hand I ordered a set of matco Master cylinders and part of a speed kit at Christmas and both were delivered the first week of January,
No complaints here,
Ivor
Kevin
G-ODJG
> [b]
_______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL
http://forums.matronics.com/viewtopic.php?p=287776#287776
budyerly(at)msn.com Guest
Posted: Mon Mar 01, 2010 8:51 am Post subject: Europa parts |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Kevin,
Sorry for your parts delay. Karen, Fiona and I have all checked with the contracted supplier and choke and throttle cables will not be available until Mid March. (Production date of delivery was Mar 15, 2010.) They are the only supplier which can make our urgent need. I have checked my stores here in the states and don't have a spare either. Our only recourse was to cobble up parts to make a one off, from other suppliers which required other parts and a non standard setup. I advised that this was not the course to go and suggested that you be advised of the delay.
My apologies if you were not advised of the above problem we are having on this critical FWF item.
Bud Yerly
Technical Assistance for Europa Aircraft.
galahav(at)YAHOO.COM Guest
Posted: Mon Mar 01, 2010 4:51 pm Post subject: Europa parts |
Try
McFarlane Aviation Products
Manufacturer of Quality Aircraft Parts at Realistic Prices
http://www.mcfarlane-aviation.com/
--- On Mon, 3/1/10, Bud Yerly <budyerly(at)msn.com> wrote:
[quote] From: Bud Yerly <budyerly(at)msn.com>
Subject: Re: Re: Europa parts
Date: Monday, March 1, 2010, 10:22 AM
Kevin,
cables will not be
make our urgent
to make a one off,
standard setup.
Bud Yerly
