hotwheels
Posted: Mon Feb 22, 2010 4:40 am Post subject: Strobe power ground? |
I have a Wheelen strobe power pack in the back of an RV-10. My forest of tabs ground is on the firewall. Should I pull the power pack ground forward or just ground locally? I can't think of a good reason the strobe would be a ground loop victim.
Thanks in advance for your reply.
Jay
Posted: Mon Feb 22, 2010 6:47 am Post subject: Strobe power ground? |
At 06:40 AM 2/22/2010, you wrote:
See illustrations in Figure Z15.
johngoodman
Posted: Mon Feb 22, 2010 11:32 am Post subject: Re: Strobe power ground? |
I think that Bob is saying you can ground it to the airframe or the forest of tabs. It brings up another question concerning aluminum RVs. If the forest of tabs is on the stainless steel firewall and the engine is grounded to it, shouldn't the forest of tabs be linked to some nearby aluminum for better grounding?
I think a braided line has been suggested, but a wire back to the actual main battery ground would also work - but how big? A #2awg is impractical. Would somethings as small as a #10awg be good enough, since it's all still attached to the airframe?
peter(at)sportingaero.com Guest
Posted: Mon Feb 22, 2010 1:54 pm Post subject: Strobe power ground? |
Let's think about what is going on here for a moment. The idea is to
allow the current to flow back to the alternator/battery without much
impediment (and without inducing ground loops in sensitive audio
circuits). The firewall is riveted to the rest of the fuselage with
perhaps hundreds of rivets, each clamping the components tightly
together. The forest of tabs has a large brass nut on it to which the
battery earth strap is connected. All the frames in the fuselage are
riveted to the skin and the longerons with 10s of rivets. Installing an
earth stud (that makes good contact with the metal) on a frame near to
the strobe power supply, and hooking the power supply up to it with a
#18 wire, will complete the circuit and achieve the desired aim with
minimum weight. Sure you can run a #10 (or #1 wire back to the forest
of tabs, but its completely redundant.
Peter
johngoodman wrote:
#40572 QB. Engine on, wing attach coming soon. Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=287678#287678
johngoodman
Posted: Mon Feb 22, 2010 3:18 pm Post subject: Re: Strobe power ground? |
Peter is right, but I do think Bob suggested some kind of supplemental grounding if the forest of tabs is on the stainless steel firewall.
MauleDriver(at)nc.rr.com Guest
Posted: Mon Feb 22, 2010 4:00 pm Post subject: Strobe power ground? |
I have no idea whether it is acceptable - but I have a #8 running from
my batteries to the forest of tabs on the firewall with the thought that
the tab is grounded to the airframe and directly. Feel good about it
and think I discussed it with Bob here sometime ago.
johngoodman wrote:
N711JG reserved
Posted: Tue Feb 23, 2010 8:28 am Post subject: Strobe power ground? |
At 01:32 PM 2/22/2010, you wrote:
<johngoodman(at)earthlink.net>
Not necessary. The only currents carried on the firewall sheet
are those few items locally grounded as shown on
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z15K3p1.pdf
| Quote: | I think a braided line has been suggested, but a wire back to the
No added value. If you do a micro-ohmmeter check between
the firewall ground block and major aluminum airframe
structure, it will be hundreds of micro-ohms.
Posted: Tue Feb 23, 2010 8:31 am Post subject: Strobe power ground? |
At 02:29 PM 2/22/2010, you wrote:
<MauleDriver(at)nc.rr.com>
from my batteries to the forest of tabs on the firewall with the
thought that the tab is grounded to the airframe and directly. Feel
good about it and think I discussed it with Bob here sometime ago.
???? Did I recommend this . . . or just offer that
it didn't hurt anything ???
Posted: Tue Feb 23, 2010 8:34 am Post subject: Strobe power ground? |
At 05:18 PM 2/22/2010, you wrote:
steel firewall.
Hmmmm . . . I'll need to search the archives on that.
I wonder if I was smoking something really good that
night. I can't imagine the thought processes that
would have made a redundant ground attractive.
I do seem to recall some folks wondering if they could
ground tail mounted batteries locally . . . or does
the system work better if battery ground is brought
forward on it's own wire.
Upon further reflection, we've been grounding batteries
in the tail on metal airplanes for a very long time.
Tradeoffs for performance are pretty small if even
measurable.
Posted: Tue Feb 23, 2010 11:15 am Post subject: Strobe power ground? |
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
You definitely didn't recommend it and from what I can see didn't even
offer a comment. My bad in suggesting you did.
Posted: Tue Feb 23, 2010 7:50 pm Post subject: Strobe power ground? |
| Quote: | > ???? Did I recommend this . . . or just offer that
see didn't even offer a comment. My bad in suggesting you did.
No problem. With as many conversations as I participate
in on-list, off-list and with clients, it's difficult
to recall sometimes just who said what to whom and
why. That's the nice thing about archives. I've got every
document I ever posted to the List on file. It's
been handy on many occasions over the years.
