longg(at)pjm.com Guest
Posted: Mon Feb 22, 2010 8:13 am Post subject: External Power Options |
I don't know what everyone is using but I definitely don't want the lead
anchor plug and related equipment I had on My Cherokee. I don't want the
Cessna variety either. These days you're hard pressed to find support
for either after business hours. Finding a 110 plug is much more
feasible.
Couldn't I just use two of the below recessed into my cowling/fuselage
and connect them directly to the battery +/-?
In that way I can just connect my charger and receive the same benefit.
http://www.pegasusautoracing.com/productdetails.asp?RecID=2848
Posted: Tue Feb 23, 2010 8:25 am Post subject: External Power Options |
At 09:43 AM 2/22/2010, you wrote:
feasible.
The Piper-Style ground power connector is light
and low cost . . . an readily serviced by folks
who are truly in FBO business. Further, you can
fabricate your own set of jumper cables with the
mating connector on one end and carry it in the
a/c for use when only a car or portable battery
is available for support.
I don't think I'd want hi-fault current terminals
hanging out just to support and exceedingly rare
need for ground power.
In 20+ years I've only be to the FBO twice to
get ground power support. And that was with weather
conditions that I would much rather not have been
flying in (-10F).
For 99.9% of your flying, ground power support
is just dead weight. If your proposed missions
put you at higher risk for needing ground power,
then some robust, universally installed architecture
will probably serve you best.
P.S. those plastic firewall feed-throughs are NOT
firewall rated just in case anyone is thinking
they might use those elsewhere . . .
