RV8-List: Adding Thinned Resin To INSIDE Of Cowling...
carl.froehlich(at)verizon
PostPosted: Mon Feb 22, 2010 4:54 pm    Post subject: RV8-List: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Recommend just priming with white epoxy primer (e.g.PPG). The primer will
seal the fiberglass and will reflect some heat. This is what I did on my 8A
and it is holding up well.
Carl Froehlich
RV-8A (525 hrs)
RV-10 (fuselage)
