johnwigney(at)windstream. Guest
				 Posted: Tue Feb 23, 2010 9:03 am    Post subject: Europa throttle cables |
				Hi Jeff,
 I had a minor problem with distortion/buckling of the original stranded
 throttle cables and changed to wire 2 years ago. I forget now why I was
 not happy with the original cable sleeve material but I replaced the
 outer Bowden sleeve with ACS item 05-15500 and used 0.062" piano wire.
 To connect the wires to the throttle handle cross bolt, I used AN111-3
 cable bushings. The wire was formed round the bushings and secured with
 safety wire and epoxy. At the carb levers, I used the standard
 components. It has worked fine. As you can see in the photo, the wire is
 just slightly bowed with the throttle wide open
 Cheers, John
 N262WF
 ORIGINAL MESSAGE
 Subject: Re: Europa parts
 I've been thinking of replacing my cables with the piano wire you
 speak of. Do you have any pictures or can you tell me how you
 connected to the throttle handle and to the carb lever?
 Thanks, Jeff R.  N128LJ Gold Rush
