Jim Berry
Posted: Fri Feb 26, 2010 11:10 am Post subject: PEM nuts |
Don McDonald turned me on to PEM nuts recently, and I thought I would pass it on. These are a fixed nut that can be used in many places instead of an AN365 nut or anchor nut. They are quicker and easier to install than an anchor nut, and they work well in places where there is not room for the legs of an anchor nut. I used some on the elevator trim tab cable attach brackets., because it was a pita to attach the access covers to the bracket with AN365 nuts and there was not enough room to attach anchor nuts to the brackets. Just drill the appropriate size hole and squeeze the nut into the hole with your rivet squeezer. Available in many sizes, materials, locking & nonlocking.
Don's brother has some available at www.missileworks.com or see www.pemnet.com for a broader selection. They recommend the SL series for a locking nut in aluminum.
Jim Berry
40482
johngoodman
Posted: Sat Feb 27, 2010 7:49 am Post subject: Re: PEM nuts |
Jim,
You've got my interest, but I need to get a little more info. What I'm seeing is a nut that you can rivet. You mentioned a squeezer, but I assume you can buck these things as well. Cost less than nutplates.
John
_________________ #40572 Phase One complete in 2011 |
partner14
Posted: Sat Feb 27, 2010 8:36 am Post subject: PEM nuts |
John, the nuts are round and have a serration all the way around so that when you squeeze it into place , it digs into the receiving metal and is fairly permanent. I probably should just send out some of these to everyone on the list. I'm sure almost all would find several suitable uses for them. Much faster and cheaper,
Don McDonald
-- On Sat, 2/27/10, johngoodman <johngoodman(at)earthlink.net> wrote:
Subject: Re: PEM nuts
Date: Saturday, February 27, 2010, 7:49 AM
--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
Jim,
John
#40572 QB. Engine on, wing attach coming soon. Panel delivery soon.
N711JG reserved
http://forums.matronics.com/visp; --> http://foru - List Contribution We -Matt Dralle, Listm/contribution" target=_blank>http://www.matronics.com/contribution
40636 |
Posted: Sat Feb 27, 2010 9:42 am Post subject: PEM nuts |
I use PEM nuts for all my electronics mounting. I like them better than
rivnuts because the PEM nuts mount from the back of the aluminum leaving
the front side flat, unlike the rivnuts that have that 'washer' on the
surface.
Linn
Don McDonald wrote:
| Quote: | John, the nuts are round and have a serration all the way around so that
Don McDonald
<http://us.mc537.mail.yahoo.com/mc/compose?to=johngoodman(at)earthlink.net>>
Jim,
nutplates.
John
N711JG reserved
<http://forums.matronics.com/viewtopic.php?p=288489#288489>
<http://www.matronics.com/Navigator?RV10-List>http://foru
Listm/contribution"
<http://forums.matronics.com/>
Jim Berry
Posted: Sat Feb 27, 2010 11:00 am Post subject: Re: PEM nuts |
John,
Don has already covered it well, but to answer your question more specifically there are no rivets involved in mounting PEM nuts. A rivet squeezer works well for setting them when the hole is close enough to an edge. In spite of Don's admonition otherwise, they can also be installed with a hammer and a hardwood block when the hole is too far from an edge to reach with your squeezer. Once a PEM nut is set, it takes a minimum of 200# of force to push it back out. So while not a secure as a riveted anchor nut, plenty strong enough for many applications, easier to install and cheaper. Try 'em and you will like 'em.
Jim Berry
40482
N15JB
