gordona23(at)earthlink.ne Guest
Posted: Mon Mar 01, 2010 6:59 am Post subject: JabiruEngine-List Digest: 2 Msgs - 02/28/10 |
Michael;
Keep the engine from turning by finding the cylinder that is near TDC
on its compression stroke and feed some 1/4 inch nylon rope into the
spark plug hole. Make sure the piston is moving up as the engine
rotates when you try to loosen the bolt, before inserting the rope. Put
in as much rope as will fit. Then slowly rotate the stuck bolt until
the engine locks up.
Now, get a hand impact tool and use it to remove the bolt.
Rotate the engine in the opposite direction and remove the rope.
Then get a good light and figure out what happened. Please let us know
how you make out.
JabiruEngine-List Digest Server wrote:
| Quote: | *
Today's complete JabiruEngine-List Digest can also be found in either of the
of the JabiruEngine-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-02-28&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-02-28&Archive=JabiruEngine
JabiruEngine-List Digest Archive
Total Messages Posted Sun 02/28/10: 2
Today's Message Index:
1. 07:54 PM - Engine Weight Comparison - Jabiru 3300 To Rotax 912 ULS (david van lanen)
2. 09:32 PM - STUCK PROP FLANGE BOLT- HELP ME PLEASE (MHerder)
Time: 07:54:28 PM PST US
From: "david van lanen" <davevanlanen(at)sbcglobal.net>
Subject: Engine Weight Comparison - Jabiru 3300 To Rotax 912
ULS
Has anyone compared the installed "wet" weight of a Jabiru 3300 to a Rotax
912 ULS, and if so, can you give me an approximate weight difference?
Dave Van Lanen
Madison, WI
Time: 09:32:51 PM PST US
Subject: STUCK PROP FLANGE BOLT- HELP ME PLEASE
Guys I'm having a really crappy night.
This evening I decided to prepare for the final installation of my 2.5" prop hub
extension on my 3300. In strict accordance with the service bulletins I heated
the flange and bolts while protecting the rubber seals with a wet rag and
I safely removed all six bolts. SUCCESS... I thought.
I thouroghly removed all of the loctite with a dental pick, then acetone on the
female side. I then used a steel brush and cleaned the female threads. I then
cleaned the bolts with a wire brush on a wheel. Acetone 3 or four more times,
cleaning very thuroghtly, making sure not to get oils from my hands on the
bolts. Cleaning, blowing with compressed air, acetone repeat... Maybe even
too many times, but I was determined to not screw this up!!!.
As a final check I decided to make sure that all was well and hand screwed the
bolt in to make sure that it went in smoothly. I used the same bolt on three
holes and it went in pretty dang smooth. The third one was nearly all the way
in (about 1/8" less than all the way in (simulating prop flange thickness))
and then it got stuck!! I thought surely it can't really be stuck, I'm not cross
threaded and it went in smooth. So I got out my wrench to back it out. Now
it's stuck enough that it turns over the engine and I don't have the prop flange
on so it's tricky to keep the engine from turning over.
I only have two theories as to how this could have happened.
1) A little bit of steel from my brush has lodged itself in between the threads???
2) The cleaning action of my steel brush rounded off the threads a bit and is
causing an extremely tight fit?
3) The loctite 620 that I thought was completely cleaned off was actually still
there in a residual form and the acetone that I thought was dry was still a
little wet and reactivated the 620?? This one is a long shot. As I really cleaned
these puppies.
I need help and worst case scenarios here. I am going to have nightmares about
having to replace a crankshaft on account of this.
What would a good machinist do to get this thing out?
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=288699#288699
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
bw12345(at)sbcglobal.net Guest
Posted: Mon Mar 01, 2010 7:36 am Post subject: JabiruEngine-List Digest: 2 Msgs - 02/28/10 |
Any one think of starting off by using a good penetrating oil? BOB
--- On Mon, 3/1/10, Gordon Arbeitman <gordona23(at)earthlink.net> wrote:
From: Gordon Arbeitman <gordona23(at)earthlink.net>
Subject: Re: JabiruEngine-List Digest: 2 Msgs - 02/28/10
To: jabiruengine-list(at)matronics.com
Date: Monday, March 1, 2010, 9:22 AM
--> JabiruEngine-List message posted by: Gordon Arbeitman <gordona23(at)earthlink.net (gordona23(at)earthlink.net)>
Michael;
Keep the engine from turning by finding the cylinder that is near TDC on its compression stroke and feed some 1/4 inch nylon rope into the spark plug hole. Make sure the piston is moving up as the engine rotates when you try to loosen the bolt, before inserting the rope. Put in as much rope as will fit. Then slowly rotate the stuck bolt until the engine locks up.
Then get a good light and figure out what happened. Please let us know how you make out.
| Quote: | *
Today's complete JabiruEngine-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the JabiruEngine-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser.
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-02-28&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-02-28&Archive=JabiruEngine
From: "david van lanen" <davevanlanen(at)sbcglobal.net (davevanlanen(at)sbcglobal.net)>
ULS
Dave Van Lanen
Madison, WI
Subject: JabiruEngine-List: STUCK PROP FLANGE BOLT- HELP ME PLEASE
From: "MHerder" <michaelherder(at)beckgroup.com (michaelherder(at)beckgroup.com)>
bolts. Cleaning, blowing with compressed air, acetone repeat.. Maybe even
these puppies.
= - The JabiruEngine-List Email Forum -nics.com/Navigator?JabiruEngine-List" target=_blank>http://www.matronics.rums.matronics.com/" ; -Matt Dralle, List Admin==========
| [quote][b]
Lynn Matteson
Posted: Mon Mar 01, 2010 7:39 am Post subject: JabiruEngine-List Digest: 2 Msgs - 02/28/10 |
Good idea...I'd forgotten about the rope trick. (getting old is hell!)
One addition to the rope trick...it would be best to make sure that
you're on the compression stroke, so as to not be pushing the rope
against the edge of an open valve. I don't know how much those puny
valves can take. This might be a case of over-thinking, but better
safe than sorry.
And I would NOT use an impact, as I'd want to be able to feel how
that bolt is progressing outward, and be able to stop it before it
got the crank all gouged out.
Lynn Matteson
Jabiru 2200, #2062, 860.4 hrs (since 3-27-2006)
Countdown to 1000 hrs~140 to go(145 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Mar 1, 2010, at 9:22 AM, Gordon Arbeitman wrote:
Michael;
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
