kjohnsondds(at)yahoo.com Guest
Posted: Wed Feb 24, 2010 12:02 pm Post subject: Figure Z? |
Hi Electrical Gurus,
I have been building a Zenith CH 801 for the past several years. It has given me time to plan for engine placement and panel instruments. Wiring the plane and panel has been a concern. In placing questions on the internet regarding wiring, several people recommended this site, along with purchasing the AeroElectric Connection. After reading the AeroElectric Connection, I was looking for a schematic that would reflect the engine I am using. I am using a Mazda rotary engine that has been built by Dave Atkins. It has a new Bosch AL394X alternator which indicates it rectifies 100% and has its own voltage regulator. The engine comes with a Microtech LT-10 RX8 13B Sequential electronic engine management system.
Basically, this is an automotive engine. It has one alternator and no magnitos. It has been build to produce about 180 hp. What Z wiring diagram fits this engine?
The chapter on batteries suggests an Odyssey PC680 battery. In doing research on this battery, it seems to be indicated for a motorcycle engine. Would it provide enough cranking power? Would the Odyssey PC925 battery be better? Zenith recommends that the battery fit under the passenger seat. Since the rotary engine is lighter than the recommended Lycoming 360, the engine will probably be place more anterior from the firewall. This will leave room to mound an Odyssey PC680 mounted to the firewall. It weighs 15.4 pounds. ThePC 925 weighs 24 pounds and may be another story.
In reading, many times it suggested that grounding the engine should be done through the engine pan. Is there a reason why the engine pan is used VS gounding directly to the engine block?
The Zenith 801 is a bush plane. My goal in finishing the plane is to keep it as light as possible. Over the last several months I have "listened" in on the discussion of fuses vs breakers and whether a transponder is needed. Basically, I believe what a person really needs is a list of parts needed to wire a panel and where they can be purchased. There were good suggestions on fuse blocks and cup holders, but many things are missing. I guess it first begins with which Z diagram I need to use and then, I can go from there.
I have studied Spanish for thirty years, and can do well. However, if we had a discussion on auto parts in Spanish, I would be lost. In reading your discussions on many issues, I feel like the kid who can tell you, "Where is the bathroom" in spanish, but is lost when asked to say more. As a read more and more, I catch a little more. However, there is a large void to fill.
Thanks for your discussions
Ken Johnson
longg(at)pjm.com Guest
Posted: Wed Feb 24, 2010 1:23 pm Post subject: Figure Z? |
Ken,
This is quite an assortment of questions. It will be best to break them down. These are typical questions which can each be answered individually. Be sure to spend time to search the list archives for individual topics. Many of them answered before.
On Batteries...
I use the PC680 which is 17AH and has plenty of umph to kick over my 200 HP IO-375. It fits my design goals. As far as weight, about 15 pounds and yes it could go under your seat. As far as true capacity is concerned, you'll need to do a full analysis of your design goals and mission before buying. Remember, contactors live near batteries, batteries live where your design needs them. Front, back, wherever.
In General any good recumbent gas battery www.bandc.biz will work well in the aircraft and can be installed in any position.
Whoever wrote the book on grounding the airplanes electrical system via the engine oil pan is a complete Gomer. Hit him over the head. When's the last time you saw a battery ground go straight to the oil pan? The language may have intended another meaning. Bolt/Weld it to the block - that's it.
Bob has several Z diagrams which lend themselves to auto or electrical dependent installation. Again, the diagrams are based on missions success and ultimately what you want or want to tolerate in your design.
A bit of time and a good checkbook will fix most of the issues.
Enjoy,
Glenn
Joined: 28 Mar 2008 Posts: 1969 Location: Riley TWP Michigan
Posted: Thu Feb 25, 2010 7:25 am Post subject: Re: Figure Z? |
Ken,
You could pick one of the Z-Drawings, add to it and modify for the rotary engine, then post your schematic for others to comment on. If you do not know which drawing to start with, try Z-11. I agree with Glenn that the ground wire should be attached to a solid part of the engine, not to sheet metal. The PC680 should be adequate and meets your goal of light weight. You could ask Dave Atkins opinion. Do you have any information on the wiring requirements for the alternator or ignition? What about a fuel pump?
Joe
_________________ Joe Gores |
Posted: Sat Mar 06, 2010 1:08 pm Post subject: Figure Z? |
| Quote: | What Z wiring diagram fits this engine?
Z-19 is a best fit for electrically dependent engines
with only one alternator.
The 680 is PLENTY . . . but you may want to consider
two batteries for alternator-out operations. One for
the engine, one for everything else.
Do you have a load analysis? I.e. a listing of all
electrical accessories and what their current demands
are for normal operations?
Don't know why anyone would do that. The most substantial
bolt to the block that is not TORQUE sensitive is the
best place to get a robust electrical connection to
the engine.
| Quote: | The Zenith 801 is a bush plane. My goal in finishing the plane is
Breakers vs. fuses are a rather small weight trade off.
Especially if your failure mode effects analysis suggests
that two batteries are called for. Transponders are only
useful if somebody on the ground (1) can even see you
on radar and (2) give a rat's you know what where you
are.
| Quote: | Basically, I believe what a person really needs is a list of parts
First you need to quantify the total energy budget
for (1) normal operations and then (2) an austere budget
for alternator out operations. Finally, decide what your
personal design goals are for alternator out endurance.
If you've got big fuel tanks then perhaps your batteries
need to be commensurately big too.
| Quote: | I have studied Spanish for thirty years, and can do well. However,
That's what we're here for. Let's discover whether
a D8 Cat is needed . . . or you can shovel enough electrons
around with a garden tractor. Also, how many yards
of dirt do you need to move? This energy management
thing is a function of TIME, LOADS and under what
conditions those loads must be functioning for you
go get on the ground comfortably with a dead alternator.
If you're flying day-vfr kinds of missions perhaps
your energy requirements are modest . . . won't know
until you list them and add 'em all up.
Finding all the bits and pieces to wire it up is
the stone simple part.
Posted: Tue Mar 09, 2010 7:43 am Post subject: Figure Z? |
Thanks Bob for taking the time to respond. In reviewing the Z-19 wiring diagram, I was wondering about the need for the extra battery? I understand the need to be able to fly the plane without fuel being the limiting factor. As far as load analysis, I do not have the flight instruments yet to determine my needs. I do not have dual ignition, so a second battery as backup for that purpose would not be needed. Thinking from another perspective, as my goal is to fly into remote areas, a second battery for utility use would be beneficial. I know AirVenture, Oshkosh is still 4 months away, but if anyone will be there with their plane, let me know. Viewing correct wiring practices would be beneficial to help me. Thanks to all who wrote to help me. Ken Johnson
Sent: Sat, March 6, 2010 3:03:36 PM
Subject: Re: Figure Z?
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
the engine.
| Quote: | The Zenith 801 is a bush plane. My goal in finishing the plane is to keep it as light as possible. Over the last several months I have "listened" in on the discussion of fuses vs breakers and whether a transponder is needed.
are.
| Quote: | Basically, I believe what a person really needs is a list of parts needed to wire a panel and where they can be purchased. There were good suggestions on fuse blocks and cup holders, but many things are missing. I guess it first begins with which Z diagram I need to use and then, I can go from there.
| Quote: | I have studied Spanish for thirty years, and can do well. However, if we had a discussion on auto parts in Spanish, I would be lost. In reading your discussions on many issues, I feel like the kid who can tell you, "Where is the bathroom" in spanish, but is lost when asked to say more. As a read more and more, I catch a little more. However, there is a large void to fill.
Bob . . -= &==
Posted: Tue Mar 09, 2010 9:40 am Post subject: Figure Z? |
At 09:40 AM 3/9/2010, you wrote:
| Quote: | Thanks Bob for taking the time to respond. In reviewing the Z-19
That's entirely up to you. The original design goal
spoke to having a battery that could support the needs
of an electrically dependent engine (in this case I think
it was a Subaru or maybe a Mazda . . . I forget) and
second battery to support everything else.
| Quote: | I understand the need to be able to fly the plane without fuel being
That's a "need" only if you define it as such.
It's your project. My suggestions and recommendations
go to the idea of continuous improvement upon the best
we know how to do. Just because some improvement exists
does not mean you need to embrace it. If a 30 minute or
one hour alternator-out endurance capability meets your mission
requirements, so be it.
| Quote: | As far as load analysis, I do not have the flight instruments yet
So perhaps you've answered your own question . . .
| Quote: | Thinking from another perspective, as my goal is to fly into
Oh shucks, you asked another question . . . don't
feel too beat up over this exercise. Very few of
our fellow builders are even aware of a value
for doing the exercise. What EVER you decide to do
after your study will make you a more competent operator
of the airplane because you UNDERSTAND more about
how it works than to 90% of the GA pilots flying
today.
