clemwehner
Posted: Tue Apr 20, 2010 9:08 pm Post subject: Using a 912 alternator cover? |
My 912 did not come with a black plastic cover to go over the rear end of the engine. Has anyone added one of these to their 912? Is there any reason not to use one to keep dirt out, etc?
Advice most welcome
Clem
Oklahoma
KFIV-912
_________________ Clem
Oklahoma
Kitfox IV-912, under construction since 1991 |
Roger Lee
Posted: Wed Apr 21, 2010 4:44 pm Post subject: Re: Using a 912 alternator cover? |
Hi Clem,
If your electrical system is exposed you absolutely should cover it. Leaving it exposed is too risky for your safety and for the engine. If something gets into this it will be very costly. I would consider this as an important issue to take care of.
I would be asking the question of where it went? They come with the cover on all 912's.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
sourdostan(at)aol.com Guest
Posted: Wed Apr 21, 2010 5:27 pm Post subject: Using a 912 alternator cover? |
Earler ones didn't.
Stan Specht
On Apr 21, 2010, at 8:44 PM, "Roger Lee" <ssadiver1(at)yahoo.com> wrote:
Hi Clem,
cover on all 912's.
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=295188#295188
pwmac(at)sisna.com Guest
Posted: Wed Apr 21, 2010 6:36 pm Post subject: Using a 912 alternator cover? |
Right, that cover came with the new and improved pricing on the
912UL. It was about a $2k item.
Paul
At 07:15 PM 4/21/2010, you wrote:
Earler ones didn't.
Stan Specht
>Hi Clem,
>cover on all 912's.
>Roger Lee
>Tucson, Az.
>Rotax Repair Center
>520-574-1080
>Read this topic online here:
lcfitt(at)sbcglobal.net Guest
Posted: Wed Apr 21, 2010 7:07 pm Post subject: Using a 912 alternator cover? |
Not true, Roger. My 1996 R-912 did not come with one. They were introduced
later to keep stuff from being dropped into the area and sticking to the
magnets. I don't think I ever had one, but I was extremely careful in that
area. I do, though agree that they are a good idea. I have one on my new
(second hand) engine.
Lowell
Sent: Wednesday, April 21, 2010 5:44 PM
Subject: Re: Using a 912 alternator cover?
Hi Clem,
on all 912's.
Roger Lee
Tucson, Az.
Rotax Repair Center
520-574-1080
Roger Lee
Posted: Wed Apr 21, 2010 8:05 pm Post subject: Re: Using a 912 alternator cover? |
Hi Lowell,
If they didn't come that way back then, I stand corrected (Thanks), but I'd certainly get one on there now. I don't think I have ever had an engine come through here without one. I know how much those parts cost and how much labor cost are to fix some of those things in that area. That cover cost $75. The parts and labor could easily make it ten+ times that to fix broken items depending on the damage.
Tucson, Az.
Cell 520-349-7056 |
Roger Lee
Posted: Thu Apr 22, 2010 11:14 am Post subject: Re: Using a 912 alternator cover? |
Hi Guys,
I talked to Rotax today and you early engine owners are absolutely right that back in the 90's the 912 engine did not have that cover. They did however say that you need one on there now. The cover is $75.
Tucson, Az.
Cell 520-349-7056 |
