Dual trim indicator buffer
PostPosted: Sun May 04, 2014 5:42 am    Post subject: Dual trim indicator buffer Reply with quote
Here's the drawing I alluded to last night . . .
http://tinyurl.com/pdacqjp
Had a power failure yesterday afternoon which
led to a discovery that my AutoCAD backup feature
had not been set up on this machine . . . lost
90% of the work and had to put it back together
this morning.
Well considered critical review from kindred herders
of electrons is solicited and welcome.
This project could be laid up on a board that
would fit into a 15 pin d-sub housing. The pots
will allow adjustment of gain over a 1 to 2x range.
Offset is good for about 30% of range. This will
allow a builder to make the trim indicator display
full, as-installed stroke of the actuator.
