				 Posted: Fri Mar 26, 2010 8:14 am    Post subject: Fuel dripping from airbox 914 ? |
				During the winter months, awaiting an opportunity for weighing the
 airplane, I kept the Europa with empty tanks.
 (Weighing has been done by now: 421Kg, CG exactly in the middle).
 Now, in preparation to first flight, I decided to fill the tanks again.
 After I swicthed on the fuel pump, I noticed that my fuel flow gauge
 indicated a flow of 2.5 L/h, without the engine running. I thought of
 air entrapped in the sensor, until I noticed that fuel was leaking from
 the cowling. Further investigation revealed that the overflow of the
 airbox on the port side was spilling fuel.
 Fuel pressure is correct.
 So, I guess there is something wrong with the port carb. So far, for all
 my Europa related problems, someone on the forum could help me to find a
 solution. Before I start disassembling the carburator, I would like to
 get a confirmation that that is what I should be doing, and if there is
 anything else that could be the cause, or if there is any other
 solution, I would like to hear.
 First flight can be performed as soon as weather cooperates and a
 suitable test pilot has time for this, so I hope this problem can be
 solved without causing a delay....
 Thanks in advance for any insight.
 Frans
		rlborger(at)mac.com Guest
				 Posted: Fri Mar 26, 2010 8:52 am    Post subject: Fuel dripping from airbox 914 ? |
				Frans,
 Off the top of my head, I'd guess a sticky float or restriction in the fuel return line.
 Any other ideas out there?
 Bob Borger
 On Friday, March 26, 2010, at 11:12AM, "Frans Veldman" <frans(at)privatepilots.nl> wrote:
 Frans
				 Posted: Mon Mar 29, 2010 1:37 pm    Post subject: Fuel dripping from airbox 914 ? |
				On 03/26/2010 05:51 PM, Bob Borger wrote:
  	  | Quote: | 	 		   Off the top of my head, I'd guess a sticky float or restriction in the fuel return line.
 It appeared to be a sticky float or valve. I took the carb out, cleaned
 it although I couldn't find anything serious that could have clogged the
 valve or float, just some residu left from evaporated fuel. Apparently
 that did it, no more fuel overflow, and the engine, after rebalancing
 the carbs, ran fine.
 My previous problem after a long pause, oil seeping into the turbo
 housing to be blown out at the first start, was this time almost non
 existent. Just a little bit of oil was collected in 4 months, far less
 than previous winter stop. I guess it was indeed a seal that needed to
 "settle".
 So, first flight can be performed any time now, as soon as weather and
 testpilots cooperate.
 Frans
				 Posted: Mon Mar 29, 2010 2:02 pm    Post subject: Fuel dripping from airbox 914 ? |
				Frans,
 Great!  Now lay in some aspirin to take care of the sore muscles in your face from the grin you are about to develop.
 Wishing you light breezes and severe clear.  Have a great first flight.
 Bob Borger
 On Monday, March 29, 2010, at 04:28PM, "Frans Veldman" <frans(at)privatepilots.nl> wrote:
 "settle".
 Frans
