Posted: Tue Mar 30, 2010 5:16 am Post subject: cooling |
David Cudney wrote:
| Quote: | After you have sealed as much as you can --If you still have a cooling
problem you, might consider louvers. Particularly if you have yet to
paint the plane. I was worried about cooling with my io 360 so I
built in louvers when I built my plane. It runs almost too cool -- I
have to block about 80% of the oil cooler in the winter in SoCAL. No
problem with heat even on hot, summer days at gross weight and climbing.
good luck
dave
IMHO, if the addition of louvers helps so much, then the cooling problem
is either not enough exit area, or the airflow path is significantly
turbulent. I'm sure that venturi effect helps suck the air out through
the louvers, so some venturi work on the exit might help.
Linn
bobbyhester(at)newwavecom Guest
Posted: Tue Mar 30, 2010 5:49 pm Post subject: cooling |
My guess is that he would not have had cooling problems to start with. I
added louvers and they do not seem to have helped much.
Surfing the web from Hopkinsville, KY
Visit my web site:
http://home.newwavecomm.net/bobbyhester/RVSite.htm
Linn Walters wrote:
> cooling problem you, might consider louvers. Particularly if you have
> yet to paint the plane. I was worried about cooling with my io 360
> so I built in louvers when I built my plane. It runs almost too
> cool -- I have to block about 80% of the oil cooler in the winter in
> SoCAL. No problem with heat even on hot, summer days at gross weight
> and climbing.
> good luck
> dave
problem is either not enough exit area, or the airflow path is
significantly turbulent. I'm sure that venturi effect helps suck the
air out through the louvers, so some venturi work on the exit might help.
Linn
