brake cylinder
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
helicat76(at)shaw.ca
PostPosted: Sun Apr 04, 2010 12:02 am    Post subject: brake cylinder Reply with quote
I have a TD1 with dual brake installation, and it appears that one toe brake cylinder is starting to weep around the oring. As I did not build the aircraft, I do not know where to find parts, and unfortunately, after hours of trying to read the numbers off the cylinder, and borrowing friends kids to see if they would fit any better, and be able to read any better than I, I have given up. I am hoping someone can tell me if I can purchase an oring and replace it, or if I need to purchase an entire assembly. All that I have been able to make out is Model 10-1 ? 0 The consensus has been that the ? is either an 8 or a 9.
Any help would be greatly appreciated.
Thanks;
Shona
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
n320wt(at)yahoo.com
PostPosted: Sun Apr 04, 2010 3:07 am    Post subject: brake cylinder Reply with quote
Shona, This is probably a Clevland part number. Any way you look at it, it will have to be removed to repair it. Most manufacturers use common o-rings and replacing them is quite easy.
Good luck
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
www.carbonfibercomposites.net
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck?
--- On Sun, 4/4/10, Helicat <helicat76(at)shaw.ca> wrote:
Subject: brake cylinder
To: glasair-list(at)matronics.com
Date: Sunday, April 4, 2010, 4:01 AM
Thanks;
Shona
http://www.matro====================
PostPosted: Sun Apr 04, 2010 8:02 am    Post subject: brake cylinder Reply with quote
Thank you Brian, very much appreciated!
Shona
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Brian Alley
Sent: Sunday, April 04, 2010 4:06 AM
Subject: Re: brake cylinder
Good luck
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
Thanks;
Shona
Checked by AVG - www.avg.com
11:32:00
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
