Glasair-List Digest: 0 Msgs - 04/03/10
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
Craymondw(at)aol.com
PostPosted: Sun Apr 04, 2010 6:00 pm    Post subject: Glasair-List Digest: 0 Msgs - 04/03/10 Reply with quote
A few years back I spotted brake fluid on my hanger floor and found it was coming out of a brake caliper. So I went to my friendly Ace hardware store and replaced the piston "O" ring with a new one and it has worked fine for the past three years or so..In a message dated 4/4/2010 3:05:11 A.M. Eastern Daylight Time, glasair-list(at)matronics.com writes:
Today's complete Glasair-List Digest can also be found in either of the
of the Glasair-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-04-03&Archive=Glasair
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-04-03&Archive=Glasair
  Glasair-List Digest Archive
  Total Messages Posted Sat 04/03/10: 0
Today's Message ================================================e the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
helicat76(at)shaw.ca
PostPosted: Sun Apr 04, 2010 9:29 pm    Post subject: Glasair-List Digest: 0 Msgs - 04/03/10 Reply with quote
Thanks, I appreciate the info. I think that Brian was right, it appears that the toe brakes are Cleveland brake cylinders. The parts manual appears to look the same for model #10-19, and the oring kit is listed for the cylinder.
As you mentioned, I have had problems with the plastic brake lines that go into the calipers, they seem to get hot, and expand, causing weeping, and required constant trimming and bleeding. I also went to the local hardware store and installed a ‘buffer’ between the plastic lines and the caliper. I basically use a high pressure grease gun hose that threads directly into the brake caliper, and requires little to adapt the other end. That has worked wonderfully, and I do not need to trim anymore lines. Recently, I have discovered that a local hydraulic supplier will make the same hoses with certified hydraulic hose for almost the same price.
Cheers;
Shona
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com
Sent: Sunday, April 04, 2010 7:00 PM
To: glasair-list(at)matronics.com
Subject: Re: Glasair-List Digest: 0 Msgs - 04/03/10
HTML Version:
Text Version:
Today's Message =======================e the ties Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List
No virus found in this incoming message. Checked by AVG - www.avg.com 271.1.1/2788 - Release Date: 04/04/10 06:31:00 [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
