planecrazzzy Guest
Posted: Sat Apr 22, 2006 6:31 pm Post subject: Dangerous or just scary |
I noticed something in these pictures that "I" consider to be dangerous
I don't know if it would pass an airworthiness inspection either....
Quiz Time.....What do "YOU" see...
http://www.milows.com/FireStar/TailSection/TailSection.htm
"I" think he should be warned about it....Just in case he doesn't go the
airworthiness route...
Gotta Fly...
Mike in MN / N381PM
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Richard Pike
Joined: 09 Jan 2006 Posts: 1669 Location: Blountville, Tennessee
Posted: Sat Apr 22, 2006 7:19 pm Post subject: Dangerous or just scary |
I would like to see the nicopress sleeves doubled up. On every wire
pictured. Nicos are cheap for the benefit that redundancy provides.
Maybe the factories have enough quality control that they can get by
with just one... we are amateurs, nicos are cheap, and redundancy is a
good thing.
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
jindoguy(at)gmail.com Guest
Posted: Sat Apr 22, 2006 10:05 pm Post subject: Dangerous or just scary |
My guess is you're looking at those single nico press sleeves on the
horizontal stablizer landing wires as well as the control cables to the
rudder.
It's an OWT that two nicos are needed on a cable. I suppose it got its start
with DIck Eipper or one of his contemporaries who first started selling kit
hang gliders. I know it was in the plans for the Seagull III I built in '73
/ '74. At least Mike admitted that the second nico was only there to contain
the cable end so you wouldn't snag the sail or yourself. In actual fact the
cable should be left sticking out the end of the sleeve 1/4" and a single
sleeve, swaged per spec's and checked with the gauge that came with the
swaging tool is all that is required to make a cable termination that will
hold past the breaking point of the cable. Wills Wing always used a thick
heat shrink tube over the sleeve and raw cable end to protect sails and
fingers. It was clear enough that you could inspect the sleeve and check the
cable end for any slippage after that last wing over.
One sure way to make a wire termination that can fail before the breaking
point of the wire is to put a bubble, the two cables do not lie flat along
side each other between the nico sleeves, in the termination between the two
nicos. I've made a few bubbled cable terminations over the years, all it
takes is to put a slight twisting moment into bringing the handles together
while swaging. I cut up every one of them and made new cables. I would
advise anyone who asked to do the same.
On 4/22/06, planecrazzzy <planecrazzzy(at)yahoo.com> wrote:
Rick Girard
"Pining for a home on the Range"
planecrazzzy Guest
Posted: Sat Apr 22, 2006 11:33 pm Post subject: Re: Dangerous or just scary |
BINGO,
Everyone's a winner.....
Also important is what you CAN"T see....I'll bet the elevator only has
one nicco sleeve on it....
You might get by without rudder....maybe you could get lucky enough
that the tail didn't "fold up"... ( doubt it ) But it could also fold "down"
But the elevator cable would be BIG trouble
.....better have a GOOD trim "backup"
It also makes me wonder about the "other" Milow...Both planes
were being built by the same people....I wonder if the Mark III is the
same way...?
Gotta Fly...
Mike in MN
NeilsenRM(at)comcast.net Guest
Posted: Sun Apr 23, 2006 7:30 am Post subject: Dangerous or just scary |
I put two nicropress sleeves on all my cables for the same reasons Mr. Pike
talks about but... Engineering data suggests that these joints a much
stronger than the cables so if they are done right there is no problem. Some
times us backyard engineers do things to our planes that we think makes them
stronger but in fact crates a weakness where there was none. The single
sleeve is normal aircraft practice.
I have seen Tim's work up close and it is shows some of the best
craftsmanship I have ever seen. I for one would not think twice of flying
anything he has worked on.
Rick Neilsen
Redrive VW powered MKIIIc
planecrazzzy Guest
Posted: Sun Apr 23, 2006 8:53 am Post subject: Re: Dangerous or just scary |
The Plans call for two nicco sleeves at each end....
If he feels safe with one , That's his choice... That's why they call it
Experimental I guess...
The DAR that I had would NOT have accepted one nicco for the
Airworthiness Cert....
Gotta Fly...
Thom Riddle
Posted: Sun Apr 23, 2006 10:40 am Post subject: Re: Dangerous or just scary |
According to 43-13 one, done correctly, is plenty strong. I'd rather have one done correctly than two done poorly.
Thom in Buffalo
Posted: Sun Apr 23, 2006 2:14 pm Post subject: Dangerous or just scary |
Mr. Pike
much
problem. Some
makes them
single
| Rick Neilsen
Hi Gang:
Here is a good publication a lot of us should stick our noses in. It
will answer a lot of questions "correctly". It is Advisory Circular
43.13-1B:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument&Highlight=acceptable%20methods
Here is a shortened version of the above url:
http://urlsnip.com/512534
The entire circular is available at this site.
I normally use two nicropress sleeves for 3/32 and smaller cable.
1/8" I use one, I think. I used 1/8" cable for my up elevator cable,
but it has been so long ago I forgot if I used two or one. Based on
how well I assemble my cables and hardware, I choose to use two
sleeves. Gives me that extra little bit of assureance that it will be
there for the duration.
I agree with what Rick Neilsen and Richard Pike had to say about
cables and hardware.
_________________ John Hauck
Titus, Alabama |
Richard Pike
Posted: Sun Apr 23, 2006 9:42 pm Post subject: Dangerous or just scary |
Well said. However...
Back in 1979 I built my first flying machine, a Quicksilver B, from
plans. Fortunately, I had an assistant, one of the test pilots from the
North American Rockwell factory located on Albany airport, (currently
Ayers Corp) who was invaluable in knowing how Things Are Done, obtaining
aircraft hardware (yes, I paid for it) and for checking us out a
swedging tool for squeezing the nico sleeves.
It was a swedging tool checked out of the Certified Tool section of the
Rockwell factory. Used for certified aircraft.
Since I had never done any swedging before, I thought it prudent to do a
few practice attempts, cable was cheap, nicos were cheap, and getting it
right seemed important. So I made a couple, and then made a short length
with a loop with thimble & nico on each end. But how to test my attempt?
For whatever reason, (don't remember why) there was a hook in the roof
of my garage, so I hooked one thimble loop over the hook, and put a big
screwdriver through the loop at the lower end. Decided that if I could
chin myself on it by holding the screwdriver with both hands and pulling
up, that would demonstrate that the 3/32 cable could at least hold 180
pounds. ( I was skinnier back then...)
So I gave it a try. It had one nico per thimble. Swedged as per the
book. Using the factory's certified tool...
When that sucker pulled out, with me pulling down on that screwdriver,
supporting all my weight on it, it smashed it into the bridge of my
nose, knocked me silly, hurt like the devil, (I remember that part best
of all) and dumped me semi unconscious on my tush on the garage floor.
Oh, the humanity...
I gave the squeezer tool back to my pal at the Rockwell factory, got a
different one, and used two nicos per thimble loop from then on.
Feel free to use as many nicos as you want, and do it by the book all
you wish, but I know how I will be doing it...
Richard Pike
Kingsport, TN 3TN0
Posted: Mon Apr 24, 2006 4:34 am Post subject: Dangerous or just scary |
all
| Richard Pike
You didn't mention if you checked your single nico with a proper
"go-no go gauge".
There is more than one way to screw up a good nico press sleeve
connection.
Titus, Alabama |
Richard Pike
Posted: Mon Apr 24, 2006 5:59 am Post subject: Dangerous or just scary |
I didn't have one. This was during my "ignorant beginner" days. Building
Quicksilver's from plans, and buying used Easy Risers from Glen Rinck.
If you live long enough, you find ways to screw up more than nico
connections. Amazing that any of us survived...
Anyway-
Had assumed that if the nico tool (large bolt cutter style) came from
the aircraft factory, it must be good, right? (Ass - u - me... oh, yeah,
right)
The Rockwell guy took it back to the factory to have it checked, and I
don't remember what the outcome was. The squeeze connection that failed
looked good, but that obviously was worth nothing.
Richard Pike
John Hauck wrote:
all
| Richard Pike
"go-no go gauge".
connection.
Kingsport, TN 3TN0
rp3420(at)freescale.com Guest
Posted: Mon Apr 24, 2006 9:05 am Post subject: Dangerous or just scary |
Rick and gang,
Rick, thank you for the kind comments about our kolbs. Just logged on
to my computer this morning to see this thread and thought I would share
my thoughts on swegded nicos.
Double nico swedging practice came from the early ultralight craze
starting back in mid 70's. These early pioneers would swedge a nico and
the cable end would snag and tear sails when setting up and breaking
down the ese early ultralights. One soulution was to nico the very end
of the cable so no cable was protruding to do such sail damage. Then
over the years the thought evolved as redundancy. Go look at any
general aviation aircraft, they only have one swedged nico.
Yes, we tested the swedges with a "go" and "no go" gauge. And we also
tested the same way Richard did, but with 300 plus pounds. Uncle Craig
even cut a swedged nico open to show me the effects of the nico swedge
squeeze. It is amazing to see how the copper will inandate into the
finest twines of the cable. One swedge, done correctly and to
specification is more than enough, the cable will break before the
swedge.
Yes, I did only use one swedge on rudder- I loose rudder, the machine
still flies. Yes, I did use two on my elevator- I loose elevator, well,
that is the only flight control that I must have. Because of this
reason, and maybe for my own mental health, I doubled up on swedges.
Again, for my own mental thoughts- five little kids w/o father
thoughts.......
As we built on both of our Kolb projects we were litterly sometimes like
the Wright bros. Fighting over exactly how things should be done,
engineered, or have been done. With these synergestic moments we would
come up with a or test that none of us would have engineered or tested
alone.
Uncle Craig and a very close friend who is an A&P and master craftsman,
and I mean "master craftsman"- we call him weird Larry. When you see
uncle Craigs Xtra in person, ask me what weird Larry did on it and I
will show you, it puts my uncle and myselfs custome work to shame. To
this day I still look at some of the details Larry did and wonder how he
did it. Larry is constantly approached by airplane restoration groups
and museums to restore WWI, WWII, golden age and classic aircraft back
to flying condition. You give Larry a 4x4' sheet of 2024-T3 and he
will place any type of bend, joggle, curl, compound curve, twist, you
name it......it's mind boggling!
Posted: Mon Apr 24, 2006 9:08 am Post subject: Dangerous or just scary |
OOOPS! Accidentaly sent rough draft reply without spell check or going
over real well--Im sure you catch my drift.???
Tim Gherkins
vitalfx0(at)qwest.net Guest
Posted: Mon Apr 24, 2006 9:27 pm Post subject: Dangerous or just scary |
Yes the other milow has only one nicco. It is because of me milow has only one nicco on his plane. again if you look at general aircraft there is not one example where I have seen two nicco's I have not seen two nicco's on any commercial aircraft and I have not seen two nicco's on any helicopters. if the press is calibrated one nicco is as strong as the cable and Old poops I don't know what you are using to swedge your nicco's to have a cable fail with only 150 lbs you must be swedging with your hands.I engineered built and test flew an airplane with a boxed and cable braced airframe 15 years ago, it was at that time I did my research on nicco's. Again one is as strong as the cable! the only time I have seen two is on hang gliders and ultralights. the reason has allready been referred to in a post yesterday.If you are so unsure of your building abilities and the aircraft you fly then maybe two nicco's will keep you in the air!!!!!!!!!!!!!!
It is because of the stupidity of people like Planecrazy,(not going to pass airworthy inspection with one nicco) and remarks from old poops and some others on this list after my friend's with my plane, that I am content to just look at what others are doing. and keeps me from commenting on anything I do, or making suggestions on the list, and have asked milo to stop posting anything about my plane. sorry but with this comment I had to speak my mind.
(all spelling courtesy of Webster)
Uncle Craig
MkIII EX 912 ULS
Warp
DO NOT ARCHIVE DO NOT ARCHIVE DO NOT ARCHIVE DO NOT ARCHIVE DO NOT ARCHIVE DO NOT ARCHIVE
biglar
Posted: Tue Apr 25, 2006 5:06 am Post subject: Dangerous or just scary |
Pretty harsh, Craig. You seemed like a fair and decent person when I met
you at Monument Valley. Lar. Do not
Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Tue Apr 25, 2006 5:58 am Post subject: Dangerous or just scary |
Larry and gang,
Your right! That was pretty harsh???? I think uncle Craig was having a
bad day? Please ignore his rant, I will apologize for his post.
Tim Gherkins
Firestar II
Posted: Tue Apr 25, 2006 6:27 am Post subject: Dangerous or just scary |
We need to move on to new things but...
In a previous post I talked about some backyard engineers changing things to
make something stronger but in fact creating weakness. I checked out a
MKIIIc last summer were the builder had changed the control wires for the
elevator from stock to what looked like 1/4 - 5/16 galvanized steel cables.
I don't remember if any of the fittings on this control system were beefed
up, I don't think so. My comment at the time was wow you must get some major
cable slap.
Now that I think more about this, I feel that this is a good example of us
backyard engineers trying to make something stronger but actually making it
weaker. The stock cables are plenty strong. Seems like someone stated that
they are rated at 480lbs. By increasing the size of the cables they fixed
some thing that wasn't broken. By increasing the size of the cables they
added weight. More importantly this weight has to be carried by pulling the
cables with considerably more force than is necessary to keep the lighter
cables suspended in the fuselage tube. When they taxi on rough ground the
stress on the control system goes up big time. The control system is only as
strong as its weakest link and the cables were likely never the weakest link
(but I'm not a structural engineer). My point is this added stress could
cause a critical control system failure just by having to carry the added
stretched cable weight.
My personal rule is don't change the structural design of your airplane
unless you KNOW you are making a overall improvement. Even then it is a good
idea to check with the designer or someone else that DOES KNOW about these
things.
Be careful out there.
Again this advice is worth what you paid for it.
Rick Neilsen
planecrazzzy Guest
Posted: Tue Apr 25, 2006 12:04 pm Post subject: Re: Dangerous or just scary |
When "I" was asking about this "one" nicco BULLSHIT...
IT WAS ABOUT SAFETY.....But it got SWITCHED around about critisizing your CRAFTSMANSHIP
Which I NEVER did....
At one time I didn't give a FUCK....
Now I'm a Pilot...
And I don't give a FLYING FUCK....
KMA- Rick the Prick
n79rt(at)kilocharlie.us Guest
Posted: Tue Apr 25, 2006 12:56 pm Post subject: Dangerous or just scary |
(CONTENTS OF MESSAGE EDITTED)
KMA- Duane the PLAIN
<SNIP>
Ahhhh, there is that eloquence you are so famous for...wondered how long
till that came out.
Jeremy "had my mouth washed out long time ago" Casey
planecrazzzy Guest
Posted: Tue Apr 25, 2006 1:09 pm Post subject: Re: Dangerous or just scary |
I guess you can only take so much of somebody TWISTING your words around til you won't stand for it .....and well....BOOOM
Whatever,
Gotta Fly
