bmoorhouse
Joined: 29 Apr 2009 Posts: 12 Location: SW England - Somerset to be precise
Posted: Thu Apr 08, 2010 7:26 am Post subject: Rotax 914 Fuel Pumps |
I have a Europa XS powered by a 914 which has two electric fuel pumps. It is always a niggling concern that if I have an alternator failure and a coincident low battery condition that both pumps would fail with consequent engine stoppage.
This may seem a naive question but is there any approved (UK) alternative using some form of mechanical pump with the 914?
_________________ _______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL |
rlborger(at)mac.com Guest
Posted: Thu Apr 08, 2010 9:54 am Post subject: Rotax 914 Fuel Pumps |
Barry,
I'm in the US and working on the installation of a mechanical fuel
pump on my 914. You can see pics of the pump and regulator on my site
on EuropaOwners.org. The pump is capable of much more pressure and
volume than necessary for the 914 which is the reason for a second
regulator. It drops the pressure down to 25 pounds for the Rotax
regulator to handle. Once I get all the plumbing issues worked out
I'llbe posting more information. If it all works as planned, you
folks in the UK can begin your own approval processes.
Bob Borger
On Apr 8, 2010, at 11:26, bmoorhouse <barrymoorhouse(at)btinternet.com>
wrote:
_______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL
http://forums.matronics.com/viewtopic.php?p=293498#293498
bmoorhouse
Posted: Fri Apr 09, 2010 2:25 am Post subject: Re: Rotax 914 Fuel Pumps |
| rlborger(at)mac.com wrote: | Barry,
Bob Borger
Thanks for the info Bob. Where does the mechanical pump fit on the 914?
I have heard of some (quite complex) solutions involving backup batteries to drive the existing electrical pumps but, to me, it would appear that this just adds a heck of lot more complexity into the circuitry (further potential failure points) without solving the core issue.
Mind you I have never heard of a single case where an electrical failure actually caused a fuel starvation problem, so maybe this is a solution to a problem that doesn't really exist, except in the most rare circumstances.
I do not have sleepless nights worrying about this as 99% of my flying is in areas where I could carry out a forced landing with a good chance of success (I hope those are not "famous last words"), and there are other potential failures that are far more likely than a total loss of all electrical power.
It was just that if there were some accepted and certificated way of doing this at reasonable cost it would be worth considering.
I look forward to seeing how you get on with your idea.
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL |
Posted: Fri Apr 09, 2010 5:02 am Post subject: Rotax 914 Fuel Pumps |
Hello Barry,
The Billet pump bolts onto the same location as the 912 mechanical
pump, on the starboard side of the gearbox.
Right now, I'm waiting on parts. I have a spacer gasket on order from
Lockwood but Rotax is changing the part and old stock is gone and new
stock has not yet arrived.
I have some additional pics to post explaining things when I return
home from travel.
I'll let the list know when it's all working.
Best regards,
Bob Borger
On Apr 9, 2010, at 6:25, bmoorhouse <barrymoorhouse(at)btinternet.com>
wrote:
914?
core issue.
Mind you I have never actually heard of a single case where an
_______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL
http://forums.matronics.com/viewtopic.php?p=293610#293610
pchristensen10(at)austin. Guest
Posted: Fri Apr 09, 2010 12:34 pm Post subject: Rotax 914 Fuel Pumps |
Just bought a 912 fuel pump from leading edge airfoils last week when
Lockwood was out of stock. Try them.
Pete
Kitfox III, 912
dan coffey
Joined: 01 May 2010 Posts: 1 Location: greensboro, nc
Posted: Sat May 01, 2010 1:02 pm Post subject: Re: Rotax 914 Fuel Pumps |
Berry,
We have been contacted by ConAir Sports in the UK and have agreed to have him do the test and LAA paper work for the BilletPump on the Rotax 914 installations.
The pump and regulator are due to be shipped on the 10th of May.. If you need any more information you can contact me via email or Skype: n2turbines.
You may also want to contact Martin Olliver "G-JOST" another Europe owner, he stopped by our booth at Sun n' Fun and has seen the pump first hand.
Dan Coffey
www.billetpump.com
bmoorhouse
Posted: Wed May 05, 2010 2:45 am Post subject: Re: Rotax 914 Fuel Pumps |
| dan coffey wrote: | Berry,
Dan Coffey
www.billetpump.com |
Thanks for the update Dan
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL |
