		jfrjr(at)roadrunner.com Guest
				 Posted: Mon May 03, 2010 2:10 pm    Post subject: antenna problems |
				Last week I indicated a problem of not receiving glide slope information on my SL-30 but was getting good localizer data, and the 430 was getting both loc and gs from the other ant.  Both radios get the VOR stuff normally. I have switched the ant. leads and found that now the 430 isn't getting the gs (but still gets the loc) and the SL-30 gets both nicely.  Thus I have an antenna problem but only in the frequency range of the glideslope (I think the gs freq. is much higher than the loc. freq.)  So what gives?  And more importantly what do I do?  The ant. in question is in the port wing tip fastened to the lower aspect of the fiberglass fairing, and grounded to the wing skin (just like the other nicely functioning ant. in the other wing tip).  The marker beacon ant. is also in that wing tip but fastened to the upper aspect of the fairing.  Is there anyway that the mb ant is interfering? Thanks,  Jay Rowe #40301
				 Posted: Mon May 03, 2010 4:00 pm    Post subject: antenna problems |
				Do you have any connectors in the wing root?  I would maybe try removing the MB antenna to see if that makes any difference, but my guess would be that either there is a no-so-great connection in one of the cables somewhere or there is a problem with the actual mounting of the antenna, or a problem with the antenna itself.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
 On May 3, 2010, at 3:54 PM, <jfrjr(at)roadrunner.com> <jfrjr(at)roadrunner.com> wrote:
		Kellym
				 Posted: Mon May 03, 2010 4:47 pm    Post subject: antenna problems |
				Any chance the MB and VOR antenna cables got mixed up?
 I think MB antenna would sorta work for VOR/loc freqs, but not GS.
  	  | Quote: | 	 		   On May 3, 2010, at 3:54 PM,<jfrjr(at)roadrunner.com>  <jfrjr(at)roadrunner.com>  wrote:
KCHD |
				 Posted: Mon May 03, 2010 4:52 pm    Post subject: antenna problems |
				Jay,
 Interesting problem.  You are correct, Glide Slope is three times higher in
 frequency than VOR or LOC transmissions.  Since antenna are resonate at odd
 multiples of operation frequencies, VOR/LOC antennas work just fine for
 Glide Slope.
  	  | Quote: | 	 		  From your note you point out the both VOR antennas are identical and mounted
 in similar fashions, one in each wingtip.  As such both antennas must work -
 unless there is some other problem.  Your note say both work at VOR
 frequencies.  I wonder however if both work equally well at VOR frequencies.
 My guess is they don't.
 I would first look at the most common culprits for such things, the antenna
 connections or less frequent a bad run of coax (the coax perhaps damaged on
 installation).    The best way to do this is with an antenna analyzer.  Most
 amateur radio operators have one.  You might try the local ham radio club.
 Someone will jump at the chance to help.  Here is a standard analyzer that
 will do anything you need:
 http://www.mfjenterprises.com/Product.php?productid=MFJ-249B
 My thinking is the problem is not so bad that you do not receive any VOR
 signals, but such problems tend to have more of an effect at the higher GS
 frequency.  I would not suspect the MB antenna unless it is very close (a
 few inches) from the VOR antenna.  Come to think about it, make sure your MB
 and VOR antenna leads are not swapped.  A MB antenna will make a poor VOR
 antenna, but it will work with strong signals.
 Carl Froehlich
 RV-10 (systems install)
 RV-8A (525 hrs)
		Bob Turner
				 Posted: Mon May 03, 2010 6:11 pm    Post subject: Re: antenna problems |
				This is a long shot - is it possible the GS is "shadowed" by the fuselage? The GS transmitting antenna is slightly offset from the runway, while the localizer is off the far end. Easy test: while on the ILS, swing the nose around 5 deg or so, to the right (if the problem antenna is on left side), see if that makes any difference.
 Otherwise, I'd make sure there are no GS/LOC splitters inadvertently in the line from that antenna.
  _________________ Bob Turner
RV-10 QB |
				 Posted: Mon May 03, 2010 6:36 pm    Post subject: antenna problems |
				Thanks for the suggestions. I even talked to bob archer today. The
 problem, he thinks, is an "unhealthy" connection at the ant.  I did
 not discuss  the possibility of switching the mb and nav ants but that
 may be a possibility since the runs are side by each all the way. That
 will be very easy to check out. I'll have more info tomorrow.  Jay
 On May 3, 2010, at 8:40 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
 >> Jay Rowe #40301
