rv10free2fly(at)yahoo.com Guest
Posted: Thu Apr 08, 2010 5:00 pm Post subject: To Magento - Or Not To Magento |
I would really appreciate your thoughts regarding the installation of a dual Plasma III ignition system with crankshaft sensor on the IO-540 engine. Would this negate the need to install a magneto system?
What is the reliability of electronic ignition systems when fitted to aircraft engines?
Additionally what are the general thoughts regrading the use of 9:1 high compression pistons on IO-540 engines please?
Your thoughts would be appreciated to enlighten the uninitiated.
Many thanks in anticipation.
Patrick Pulis
Adelaide, South Australia
Kelly McMullen
Posted: Thu Apr 08, 2010 6:06 pm Post subject: To Magento - Or Not To Magento |
9:00 to one pistons....if you are trying for better economy,
perhaps...but I would put a MP limit of perhaps 28" MP if you use them
at sea level std or colder conditions. 100LL is going to disappear,
we just don't know how quickly. Stock pistons of 8.5 to 1 are
certified to run on 91/96 fuel, and most any unleaded avgas
replacement will certainly meet that requirement.
As to dual electronic.....does it matter whether there is 99%
reliability or 99.994% reliability? Do you want to risk that 1% or
.006%? Will 2 totally independent electrical systems be 100% reliable?
Your choice of what risks you want. Are magnetos 100% reliable?
Obviously not or someone would design a cylinder to have a single plug
optimally located. Certainly 2 electronic systems are very reliable as
long as they both have sufficient electrons to drive the electronics.
My question is whether the benefits of a single Plasma III are worth
the cost and effort to have 2 different systems. Certainly there is
better cruise economy in theory, but no difference at full power. If
magneto equipped with Slick Start there should be no difference in
starting, so are the cruise benefits worth the trouble and cost?
On Thu, Apr 8, 2010 at 8:32 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
| Quote: | I would really appreciate your thoughts regarding the installation of a dual
aircraft engines?
Patrick Pulis
A&P/IA, EAA Tech Counselor
KCHD |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Thu Apr 08, 2010 6:12 pm Post subject: Re: To Magento - Or Not To Magento |
I have one and one.
Left is an impulse mag powering the bottom plugs.
The right is a P III on my IO-540 powering the upper plugs.
My 2 cents,
I like the split, I feel I am getting most all the advantages of the electronic ignition (single vs dual electronic) and if it were to fail (mechanical or total loss of electrical), the backup of the mag.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Jim Berry
Posted: Thu Apr 08, 2010 8:17 pm Post subject: Re: To Magento - Or Not To Magento |
I discussed both of these points at length with Allan Barrett when I was ordering my engine. His take was that 9 : 1 pistons gave a modest increase in performance, with no decrease in reliability or TBO. I wanted to do one mag and one electronic ignition. He was not willing to build an engine with electronic ignition for a variety of reasons, but would delete one mag if I wanted to install an electronic myself. He convinced me to go with 2 mags.
Allan, chime in if I have misrepresented you position.
Jim Berry
40482
Robin(at)PaintTheWeb.com Guest
Posted: Thu Apr 08, 2010 9:39 pm Post subject: To Magento - Or Not To Magento |
Jim,
I purchased the BPE IO-540 with FF Cold Induction and 9:1. I
ordered one mag and was going to do the same thing with the hope that PMag
would prove out before I flew or go with a Plasma III. At some point along
the way I decided to just hang a second mag on and call it good for the
first year of flight so I ordered a second mag. I happened to luck out and
buy two mags that both required an the AD before first flight. In hind
sight I wish I would have installed an electronic ignition on one side
strictly for the better burn. I also have come to believe an elec.
Ignition may help with part of my temp issues (James Cowl & Plenum; nuff
said).
YMMV,
Robin
martinaerodrome(at)gmail. Guest
Posted: Fri Apr 09, 2010 5:33 am Post subject: To Magento - Or Not To Magento |
I have 1950 hours on my RV8 in the 10 years of operation. The first 950 hours were with a IO360AlB6 Lycoming with 10to l pistons and dual electronic lightspeed ignition. I WOULD NOT RECOMMEND THE USE OF 10-1 PISTONS. AFTER 951 hours of operation they almost killed me. I noticed with the last oil change at that time there was a substantial (not a trace) of metal bearing material in the oil filter. I was alarmed. I removed a cylinder and piston and discovered that there was NO BEARINGS LEFT on the connecting rod to crankshaft bearings. Needless to say, I was quite alarmed. I then removed the other cylinders and saw that all 4 rod bearings were gone.The crankshaft etc. were damaged beyond repair.After that scare, I decided that I would buy a NEW engine. I always wondered why people would spend the money required for a new engine rather than overhaul a second hand used engine. I had just returned home in wisconsin after a 1200 mile flight from florida when this all happened. Needless to say, I think that the BIG GUY UPSTAIRS was sitting on my shoulder. At this time, Lycoming had just introduced their IO390A1B6 210 hp engine, so I spent my kids inheretance and bought a NEW engine from Barrette Performance Aircraft engines in Tulsa. I am happy with this engine. It has real power increase over the 10-1 360. I noticed a average speed increase of approx 10 mmph and a climb increase of approx 500 plus fpm. Average fuel consumption at 23/23 manifold press/rpm is 9 gallons per hour.
If you wish to discuss this, please do not use internet,because I do not have time for replies. You may call me (at) 920 619 6968.
Dick Martin
RV8 N233M
the fast one
On Thu, Apr 8, 2010 at 7:32 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
[quote] I would really appreciate your thoughts regarding the installation of a dual Plasma III ignition system with crankshaft sensor on the IO-540 engine. Would this negate the need to install a magneto system?
Patrick Pulis
get="_blank">http://www.matronics.com/Navigator?RV10-List
ttp://forums.matronics.com
bcondrey
Posted: Fri Apr 09, 2010 5:50 am Post subject: Re: To Magento - Or Not To Magento |
There are a few of us running dual LSE ignitions and very happy with the result. As has been pointed out, there is huge benefit from the first electronic ignition, very little with the second. If you do go with dual electronic ignitions just recognize the dependence on electrons flowing. There are multiple ways to mitigate this ranging from a simple, small second battery setup to the more sophisticated AeroElectric Z-14 architecture. Once you've addressed that the reliability is at least as high as magnetos. I for one am extremely happy with my setup.
I'd also point out that it's likely that you'll have an all electric panel of some sort and will want some sort of way to mitigate electrical failure anyway so it's not much of a leap to include dual electronic ignitions into that equation.
If you get an engine already equipped with new mags, I'd be inclined to just replace one with electronic and keep the new mag in place. When that hits OH time just swap it out with the one that the electronic ignition replaced. When you hit the 1000 hour mark and it's time for the second mag to need OH you'll be in a much better position to evaluate from your own experience.
With regard to the pistons - given the current fuel situation I'd stick with 8.5:1. If you go higher you'll be increasing the potential that a replacement fuel won't have sufficient detonation margins. The gain from installing slightly higher compression pistons is minimal however if there's an issue that requires you to drop back down to 8.5:1 you'd have to pull all cylinders, replace pistons & rings, rehone, reinstall cylinders and go through a break-in again. Up to you to decide whether it's worth it.
Bob
N442PM
coop85(at)verizon.net Guest
Posted: Fri Apr 09, 2010 6:46 am Post subject: To Magento - Or Not To Magento |
I went with one electronic ignition for the upper plugs and a mag for the lower for both my RV-6 and RV-10 and it’s worked great. Everything I had read indicated 95% of the benefits were gained by the first electronic ignition and I liked the simple reliability of the mag so it seems like a good combination, it was also cheaper which is a plus. A lot of folks are happy with the dual mag, just realize there is some extra complexity with backup electrical systems and batteries that you need to consider.
Good luck,
Marcus
40286
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Thursday, April 08, 2010 8:33 PM
Subject: To Magento - Or Not To Magento
Patrick Pulis
- The RV10-List Email Forum utilities such as List Photoshare, and much much --> http://www.matronic=================[/b][/quote] - MATRONICS WEB FORUMS via the Web --> http://forums.matronics.comstyle='mso-spacerun:yes'> - List Contribution Web Site style='mso-spacerun:yes'> Thank you for your generous style='mso-spacerun:yes'> -Matt style='mso-spacerun:yes'> --> http://www.matronics.com/c=[/b] [b]
bkbrown(at)minetfiber.com Guest
Posted: Fri Apr 09, 2010 7:49 am Post subject: To Magento - Or Not To Magento |
Just wondering out loud here, if you were going to run one electronic ignition and one magneto, why would you have the magneto firing the upper plugs, when its generally the lower plugs that have fouling problems. In my experience, electronic ignition keeps the plugs much cleaner and fires them a little hotter.
Also, whether you believe the manufacturer’s claims or not, I think we need to look to the users of the G3 systems and get their takes on the benefits and drawbacks of the system. You might call Larry Vetterman (www.vettermanexhaust.com) and talk with him about his experiences running the G3 in his RV. I know Larry, and know he’s tried every electronic ignition system out there. He has no financial interest in G3. When he finds an ignition system he likes, and can document fuel flows, power settings and general ease of use…I listen. He had previously installed, tested, and subsequently removed dual Lightspeed ignitions.
Anyone who saw the demo in the G3 booth at Oshkosh last year would certainly remember the difference in firing power between mags and the G3. That demo and a visit with Larry Vetterman have sold me on taking a serious look at the system, I already have Bendix magnetos on my Barrett engine, so I can easily still bolt on the G3. Is anyone on this list running the G3?
Bob Brown
40871
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Friday, April 09, 2010 7:46 AM
Subject: RE: To Magento - Or Not To Magento
Good luck,
Marcus
40286
Patrick Pulis
<pr - The RV10-List Email Forum utilities such as List Photoshare, and much much --> http://www.matronic=================
- MATRONICS WEB FORUMS via the Web --> http://forums.matronics.comstyle='mso-spacerun:yes'> - List Contribution Web Site style='mso-spacerun:yes'> Thank you for your generous style='mso-spacerun:yes'> -Matt style='mso-spacerun:yes'> --> http://www.matronics.com/c= 0123456789012
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Fri Apr 09, 2010 10:41 am Post subject: To Magento - Or Not To Magento |
We have a Lightspeed on the top plugs with a magneto on the bottom plugs.
With a long taxi to the runway from the hanger, our procedure is to lean
aggressively after startup. In 150+ hours I have never had any issues with
plug fouling. To date, the Lightspeed has been excellent with no issues.
We start on the Lightspeed (Left).
Jim Combs
N312F
On Fri, Apr 9, 2010 at 11:48 AM, Bob and Karen Brown <bkbrown(at)minetfiber.com
[quote] Just wondering out loud here, if you were going to run one electronic
a little hotter.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
jcumins(at)jcis.net Guest
Bob
Being a old A&P mechanic and have extensive experience with mag’s and electronic ignitions on a Smith mini plane we race at Reno every year. I am going with the G3 system on my RV-10. We are running the 3rd generation of E-Mags on the biplane we race and now they seem to be doing very well.
The first season with electronic ignitions were p-mags and we maydayed every race. The engine broke the starter mount it shook so hard. We now have dual e-mags and on version 3 and they run great so far with 2 full seasons on them.
I have talked to the owner of G-3 and was very impressed and the design and redundancy makes total since to me.
Just my 2 cents worth.
John G. Cumins
40864 emp 95% done wings kit on the shelf
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob and Karen Brown
Sent: Friday, April 09, 2010 8:49 AM
Bob Brown
40871
Good luck,
Marcus
40286
Patrick Pulis
- MATRONICS WEB FORUMS via the Web --> http://forums.matronics.comstyle='mso-spacerun:yes'> - List Contribution Web Site style='mso-spacerun:yes'> Thank you for your generous style='mso-spacerun:yes'> -Matt style='mso-spacerun:yes'> --> http://www.matronics.com/c= | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution | 0123456789 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | <="" span="">http://www.matronics.com/Navigator?RV10-List | 5
Posted: Fri Apr 09, 2010 11:04 am Post subject: To Magento - Or Not To Magento |
That’s good info, I was just wondering why one would run the E-ignition on the top instead of the bottom. Is there an advantage in running it that way or a reason not to run it the other way?
Bob Brown
40871
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs
Sent: Friday, April 09, 2010 11:38 AM
Subject: Re: To Magento - Or Not To Magento
We have a Lightspeed on the top plugs with a magneto on the bottom plugs. With a long taxi to the runway from the hanger, our procedure is to lean aggressively after startup. In 150+ hours I have never had any issues with plug fouling. To date, the Lightspeed has been excellent with no issues.
Jim Combs
N312F
On Fri, Apr 9, 2010 at 11:48 AM, Bob and Karen Brown <bkbrown(at)minetfiber.com (bkbrown(at)minetfiber.com)> wrote:
Bob Brown
40871
AV8ORJWC
Posted: Fri Apr 09, 2010 11:37 am Post subject: To Magento - Or Not To Magento |
Coming out of hibernation on this one.
Whether the topic is "Safety of Glass Cockpit" or "To Magneto or Not To" those of you choosing to deviate need to make a personal choice based on your risk quotient. Too many builders go with the newest, sexiest or golly forbid - the cheapest. In that journey to an all too quick of a conclusion often reliability is downplayed. Most RV-10 pilots are not ready for a catastrophic engine loss during flight, the flight of the aircraft to a safe walk away landing or what the hell caused that, question as your anatomy puckers?
If your knowledgeable, if its experimental and if you choose well, then this topic is not a big deal. Slick Mags and their AD last year hit a lot of owners by surprise. Many have waited for a six banger P Mag option as long as Eggenfelner/GAMI/Epic/Eclipse and others come out with new alternatives, others are disciples of electronic ignitions and purport to drink the Kool-Aid of one or two at a time. They are all within acceptable reliability range. I have yet to read the consequence of a lightning strike on your choice. My first flight in April of 1973 was a direct hit on take-off as a Zero Time Student Pilot.
After 36 years (oops 37 got to make way for the kids out there), I find myself dealing with Lightning Strikes on Part 121 Turbo-props many nights while the RV-10 builder community sleeps. We almost have an unlimited budget, whatever time it takes to remediate the damage "Safe and Compliant" and a score of trained professionals who know what they are doing (oh yeh, and we ALL hate repairing lightning strikes). Whether it is spark ignition systems, composite charring, melted rivets, zapped electronic EFIS or wiring systems I am waiting for someone to do a T chart on the pluses + and minuses - of each. There have been a lot of good and a few strong points made here. So far the noise of the crowd is not real clear on the Risks… (Except Kelly and is 99.994% calculation). At work, we deal with the 00.006% time that it all goes to shit. May none of you ever have to.
Keep your skills sharp, fly often, land safe and question yourself often
John Cox
40600
Bob Brown
40871
Good luck,
Marcus
40286
Patrick Pulis
- MATRONICS WEB FORUMS via the Web --> http://forums.matronics.comstyle='mso-spacerun:yes'> - List Contribution Web Site style='mso-spacerun:yes'> Thank you for your generous style='mso-spacerun:yes'> -Matt style='mso-spacerun:yes'> --> http://www.matronics.com/c= [quote]http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution - The RV10-List Email Forum -[/u][/b][/u][/b][/u][/b][/u][/b][/u][/b] --> http://www.matronics.com/Navigator?RV10-List[b][u] - MATRONICS WEB FORUMS -[/u][/b][/u][/b] --> http://forums.matronics.com[b][u] - List Contribution Web Site -[/u][/b] Thank you for your generous support![/u][/b] -Matt Dralle, List Admin.[/u][/b] --> http://www.matronics.com/contribution[/u][/b] [b]
dmaib(at)mac.com Guest
Posted: Fri Apr 09, 2010 12:08 pm Post subject: To Magento - Or Not To Magento |
I think the reason many, if not most, of us put the Lightspeed on the top is that it is considerably easier to run the wiring and mount the hardware on top of the engine. 1 1/2 years and 220 hours with LS on top and mag on bottom with no problems.
$.02 worth
David Maib
40559
flying
Bob Brown
40871
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Jim Combs
Jim Combs
N312FOn Fri, Apr 9, 2010 at 11:48 AM, Bob and Karen Brown <bkbrown(at)minetfiber.com (bkbrown(at)minetfiber.com)> wrote:
Bob Brown
40871
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
jchang10
Posted: Fri Apr 09, 2010 12:38 pm Post subject: To Magento - Or Not To Magento |
A few months ago, I didn't think G3 supported 6 cylinders. Looking
again, i still don't see any support other than for 4 cylinders. Does
anyone know any different?
http://www.g3ignition.com/order.html
Jae
40533
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Posted: Fri Apr 09, 2010 1:33 pm Post subject: To Magento - Or Not To Magento |
FWIW, I just got off the phone with Thomas Shpakow, who owns G3. He said
his system doesn't care how many cylinders (4, 5, 6, 9, etc), since his
system runs on top of a magneto. It's not changing the timing, only
boosting the spark. He said he's sold 7 systems to RV-10 builders and has
been running a 6 cyl version on his plane since he came up with it two years
ago.
Bob Brown
40871
n277dl
Posted: Fri Apr 09, 2010 1:36 pm Post subject: Re: To Magento - Or Not To Magento |
Yes, it'll support 6 cyl. Doesn't replace the mags. I've installed the G3 but not started the engine yet.
Hopefully flying in the next couple months.....
Doug
RV7A flying 850hrs
RV10 Fuse painted and at the hangar, installing panel, trying to get wings painted....
Posted: Fri Apr 09, 2010 2:51 pm Post subject: To Magento - Or Not To Magento |
According to the owner it does support 6 cyl
John G. Cumins
jchang10
Posted: Fri Apr 09, 2010 6:19 pm Post subject: Re: To Magento - Or Not To Magento |
Thanks. I stand corrected. In fact, in the current price list PDF file, it does mention 6 cylinder harnesses, etc.
http://www.g3ignition.com/currentprice11.01.09.pdf
Well, that's certainly nice to know. Hopefully, those 7 rv-10 builders can provide some success reports for future reference.
Jae
| jcumins(at)jcis.net wrote: | According to the owner it does support 6 cyl
John G. Cumins
Kelly McMullen
Posted: Fri Apr 09, 2010 6:29 pm Post subject: To Magento - Or Not To Magento |
It would be even better if they were able to do a 3 leg GPS run with
G3 enabled, followed by one with it disabled, on stock magnetos, so we
could have a real world estimate of power difference.
On Fri, Apr 9, 2010 at 7:19 PM, jchang10 <jc-matronics_rv10(at)jline.com> wrote:
KCHD |
