MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Wed Apr 28, 2010 2:48 pm Post subject: Nicopress Sleeves-Control Rigging Question |
Control rigging question here. The standard supplied tin coated copper sleeves provided by zenith are marked part number S-11-004. The ones available at spruce have a different part number alltogether. Are the ones furnished by Zenith Mil spec? Is there such a thing as a milspec nicopress since they were really originally designed for phone guy wires?
I am making some control cable ends and I want to make sure that I'm doing everything right, but I can't find too much literature on this. I know the crimp procedure 1Middle, 2thimble side 3back side, and I know to use my go/ no go gauge for a size M, but I just want some reassurance. Are the S-11-004 the same as what is available at spruce? I just figure it only takes one cable slipping loose to really ruin your day.
I'm using the two bolt cheapo crimper available at spruce which works well but is slow. I cut a couple crimps in half with a drem and it is nice to see that every thing is compact with no voids.
Is it typical to proof test cables IF so to what pressure 7x19 is supposed to be good for 2300 #, do you test to 1/4? I can't image that these control cables would ever actually hae more thann 150 pounds on them.
Talk to me.
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Apr 28, 2010 5:23 pm Post subject: Re: Nicopress Sleeves-Control Rigging Question |
I bought the Spruce equivalent tin coated sleeves and they were the same parts as the ZAC supplied stuff. Go for it. I used the cheapo 2-bolt crimper also.
_________________ David Gallagher
Cincinnati, OH area |
chuck960
Posted: Wed Apr 28, 2010 8:18 pm Post subject: Re: Nicopress Sleeves-Control Rigging Question |
You might get more life from that crimper if you replace the washers with larger ones. Two per bolt. Hardened if you can find them. Keep the threads oiled up.
I made cables for a sailboat. You could tow your car with these cables.
There's an idea, make up a test cable and tow your car. You will get an idea of how strong your crimp is. The cable will probably break first.
dsleepy47
Posted: Thu Apr 29, 2010 3:18 am Post subject: Nicopress Sleeves-Control Rigging Question |
t sounds like you have a good grasp of the basics. Go to AC 43.13-1B Chapter 7 page 7-29 and perform the test as listed. Your instincts are good, will the cable be stressed in normal use to anything near the design limits, probably not but what is the up side to not performing the work IAW acceptable data. Make sure to follow the safety precautions listed in the AC, cables can be dangerous. If you don't have the AC you can download Chapter 7 or the whole thing from the FAA web site.
Deems Herring A&P
| Quote: | Subject: Zenith601-List: Nicopress Sleeves-Control Rigging Question
Date: Wed, 28 Apr 2010 15:48:24 -0700
--> Zenith601-List message posted by: "MHerder" <michaelherder(at)beckgroup.com>
Talk to me.
One Rivet at a Time!
http://forums.matronics.com/viewtopic.php?p=296083#296083
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy.
_________________ dsleepy47
N1491R |
afterfxllc(at)aol.com Guest
Posted: Thu Apr 29, 2010 2:39 pm Post subject: Nicopress Sleeves-Control Rigging Question |
If you go to Lowe's they have a crimper that looks like a bolt cutter and you can do 3 crimps in about 2 min.
they are by the chains and cable's in hardware and they cost like 24.00 but well worth it.
just a thought
jeff
