woxofswa
Posted: Wed Apr 14, 2010 8:22 pm Post subject: Firewall access |
I need to punch a couple of access points through my firewall for my A/C lines.
Unfortunately, I don't have my finishing kit or motor mount yet.
I am considering one point directly (an inch or two) below the heater valve on the Captain's side and the other about the same height over on the FO side near the sidewall.
My biggest fear is running these and later finding out that they conflict with something else. Can anyone ahead of me comment on those locations?
Thanks in advance.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
woxofswa
woxofswa
woodsie
Posted: Fri Apr 16, 2010 11:04 pm Post subject: Firewall access |
Hey all.
This sounds like a stupid question, but I'm about to start work on my
empennage in a few weeks and am getting my workshop sorted out.
I've got a good set of tools coming from PlaneTools, but am wondering about
setting up a work bench. How big? I'm going to build the bench from
scratch, so wondering how wide and long would be good, since I can make it
any dimension then I might as well make it right...
Tony Woods
Not started anything yet!!
_________________ Woodsie
waiting for Empennage to arrive  |
rwwende
Posted: Sat Apr 17, 2010 3:19 am Post subject: Firewall access |
I went with 4x8
rleffler
Posted: Sat Apr 17, 2010 3:47 am Post subject: Firewall access |
I went with two of the standard EAA benches. Small enough they don't get in
the way in a two car garage, but when you put them end to end, just right
for working on the wings.
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
n223rv(at)wolflakeairport Guest
Posted: Sat Apr 17, 2010 4:41 am Post subject: Firewall access |
I have a 4x4 and a 4x8.
On Apr 17, 2010, at 3:00 AM, "Tony Woods" <twoods(at)sesa.af> wrote:
Hey all.
wondering about
make it
Tony Woods
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Sat Apr 17, 2010 5:30 am Post subject: Re: Firewall access |
Hey Myron,
That not only looks slick and professional, I can't believe you did that in two days! My owner/pilot has been talking a/c after he came back from his cross training in TX -- can you imagine doing all this after the fact? Sheesh!
Hey Tony,
We actually used the crates that parts came in. One is 4X8, the other 4X9.5 -- just turned them upside down, stuck some legs on them and covered the top with carpet.
Oh yeah, it would be a good idea to start a new thread next time when you change the subject.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
woodsie
Posted: Sat Apr 17, 2010 5:37 am Post subject: Firewall access |
Thank you! I think a big piece of solid ply is going to work well.
I'll keep you posted on progress in a month or so when my boys and I
get started. I'm sure I'll have many newbie questions
Cheers
Tony
Sent from my phone
On 18/04/2010, at 0:39, Michael Kraus <n223rv(at)wolflakeairport.net>
wrote:
> Hey all.
> wondering about
> make it
> Tony Woods
rene(at)felker.com Guest
Posted: Sat Apr 17, 2010 6:20 am Post subject: Firewall access |
I already had a sturdy 4 X 8 workbench with a vise mounted on it. I added
two fold up tables from Costco. They are easy to use, move and put out of
the way when needed. Once i was working on the fuselage, I made a 4 X 6
platform ....about a foot high with carpet on the top.....to work on the
fuselage and cabin top. Once I was ready to put the gear on, I put the
fuselage up on the Costco table.
Things to consider....
Dimbling table....where to build it and/or put it.
You will need an 8 foot flat surface for the trailing edge of the flaps
The wings are 12 feet long, I used the two fold up tables
I had plenty of room in my garage during the summer because I could move my
wife's car outside, but in the winter I could not use her side. So I had to
shuffle stuff around to work. Unless you have plenty of room, I would not
get to carried away building stuff until you need it. Items you may or may
not need...
Wing stands
Fixture for wing leading edge and fuel tanks
Fixture for flaps
Rene'
801-721-6080
Posted: Sat Apr 17, 2010 6:38 am Post subject: Firewall access |
One more thing. When you are building your table(s) you need to make sure
at least one edge of the table deck extends beyond the table frame. For
example while I was working on the wing, I clamped the spar to the table.
Rene'
801-721-6080
rv10rob(at)gmail.com Guest
Posted: Sat Apr 17, 2010 7:14 am Post subject: Firewall access |
Space in my garage is at a premium, so I made a 8x2 and 5x2 modified EAA tables, which have worked great.
On Sat, Apr 17, 2010 at 6:37 AM, Tony SESA <twoods(at)sesa.af (twoods(at)sesa.af)> wrote:
[quote]--> RV10-List message posted by: Tony SESA <twoods(at)sesa.af (twoods(at)sesa.af)>
Thank you! I think a big piece of solid ply is going to work well. I'll keep you posted on progress in a month or so when my boys and I get started. I'm sure I'll have many newbie questions
Cheers
Tony
Sent from my phone
On 18/04/2010, at 0:39, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
| Quote: | --> RV10-List message posted by: Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)>
On Apr 17, 2010, at 3:00 AM, "Tony Woods" <twoods(at)sesa.af (twoods(at)sesa.af)> wrote:
| Quote: | --> RV10-List message posted by: "Tony Woods" <twoods(at)sesa.af (twoods(at)sesa.af)>
Hey all.
Tony Woods
es Navigator to browse
s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Matt Dralle, List Admin.
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
dogsbark(at)comcast.net Guest
Posted: Sat Apr 17, 2010 8:47 am Post subject: Firewall access |
To make two benches, I got four of the adjustable sawhorses (Stanley) and a couple solid core doors placed on top. This was good for reconfiguration and easy to take apart, then lean against the wall to get them out of the way. I think the doors were around $50.00 each. I was able to drill into them, then eventually dispose of them when finished. Over a period of years, it can cup a little ....just add a third sawhorse in the middle. Easier to clamp to these benches, too.
Also, used some of the tool chest liner that comes in rolls on top of the benches. This kept aluminum fragments away from the parts and minimized scratching.
Here's a pic: http://websites.expercraft.com/seanb/images/55746378243547ff171177.jpg
Sean Blair
COS RV-7A
