Engine mounting
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
tstrong(at)ida.net
PostPosted: Sun Apr 23, 2006 8:26 am    Post subject: Engine mounting Reply with quote
Has anyone hung the engine with the wings and tail off?
I'd like to do that but was wondering if the CG would be too far and make
the front end too tippy.
Tom Strong RV9A Flying this year!!
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
jdisher(at)intergate.com
PostPosted: Sun Apr 23, 2006 8:45 am    Post subject: Engine mounting Reply with quote
Works fine. Only tipping problem is if you crawl back in the fuselage to
hook up antenna, then you can get areal lesson in weight and balance.
John Disher-finding out that last 10% takes 90% of the time
gbrasch(at)earthlink.net
PostPosted: Sun Apr 23, 2006 9:08 am    Post subject: Engine mounting Reply with quote
Probably wouldn't hurt to weigh down the tail for extra security anyway.....
Glenn in Arizona -9A finishing kit ordered
Van's Aircraft Belt Buckles
http://home.earthlink.net/~gbrasch/
jc(at)INFONET.COM.BR
PostPosted: Sun Apr 23, 2006 9:40 am    Post subject: Engine mounting Reply with quote
Care must be taken with the engine on and no prop, if you decide to go inside the tunel
(to instal antennas, e.g). The tail will go down. It almost happenned with me inside.
JC - Aracaju - Brasil
-9A 90997
Flying 120 hs
PU-JCI
http://websites.expercraft.com/jcmm/
dthomas773(at)sbcglobal.n
PostPosted: Sun Apr 23, 2006 9:42 am    Post subject: Engine mounting Reply with quote
That's what I did. The center section is pretty close
to center of gravity but I put 2 horses under it. 1
under the center section and another under the next
bulkhead aft. Once up on the gear the fuselage is
pretty hight to work on. You can customize your
horses with nice short legs to keep things down to a
comfortable hight.
Dennis Thomas N164DV 269 hours.
bill(at)repucci.com
PostPosted: Sun Apr 23, 2006 9:43 am    Post subject: Engine mounting Reply with quote
I take you are all talking about -9A's and not -9's?
I'm about to pull the wings and tail off so I can reposition my -9 to
hang the engine. Yes, mine is a tail dragger.
Thanks for the help.
Bill
www.repucci.com/bill/baf.html
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
