Harold Lanfear
Joined: 02 Dec 2006 Posts: 6 Location: West Grove, PA
Posted: Sun Apr 25, 2010 4:17 am Post subject: Nav Audio Connection |
I'm currently wiring the audio portion of my Garmin 430W into the intercom. The company that did the harness simply labeled this wire as "Nav Audio, for future use" When I traced the pinouts, I discovered this wire to be the VOR / ILS Audio Hi & Lo wires. Can I connect these to the same pins as the Com Audio without a problem?
I'm using Vern Little's AMX-2A Audio Mixer for some audio inputs from my Grand Rapids EIS and some warning systems so I could use this for the Nav input as well, if that would be better.
Thanks for the help in advance.
Harold Lanfear
_________________ Kitfox 660+ Hrs, RV-8 70% done/ 90% to go! |
Posted: Sun Apr 25, 2010 6:14 am Post subject: Nav Audio Connection |
At 07:11 AM 4/25/2010, you wrote:
| Quote: | I'm currently wiring the audio portion of my Garmin 430W into the intercom. The company that did the harness simply labeled this wire as "Nav Audio, for future use" When I traced the pinouts, I discovered this wire to be the VOR / ILS Audio Hi & Lo wires. Can I connect these to the same pins as the Com Audio without a problem?
| Yes. LO = ground, HI = nav audio source
I'm using Vern Little's AMX-2A Audio Mixer for some audio inputs from my Grand Rapids EIS and some warning systems so I could use this for the Nav input as well, if that would be better. |
Normally one would gather all audio sources together into
a single mixer . . . so yes, that would be preferre.
Bob . . . [quote][b]
stein(at)steinair.com Guest
Posted: Sun Apr 25, 2010 9:48 am Post subject: Nav Audio Connection |
Hi Harold,
Not really a good idea to hook those together as they are meant for a separate channel on either the mixer or audio panel/intercom so you can shut the “ident” stream off when no desired. The LOW isn’t that big of a deal (Low mostly = ground).
Cheers,
Stein
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harold Lanfear
Sent: Sunday, April 25, 2010 7:12 AM
To: AeroElectric-List(at)matronics.com
Subject: Nav Audio Connection
Harold Lanfear
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
