clemwehner
Posted: Sun Apr 18, 2010 8:23 pm Post subject: water temp sender location? |
KF friends,
Where do I install the sender for a water temp guage on a 912 UL installation?
I appreciate any ideas.
Clem
Oklahoma
KFIV-912
_________________ Clem
Oklahoma
Kitfox IV-912, under construction since 1991 |
sdemeyer
Posted: Mon Apr 19, 2010 5:36 am Post subject: water temp sender location? |
Hi Clem, you won't find a water temp sender location on the 912. Most people use the CHT gauge instead as it should be similar temps as water. On my 912, I installed a water temp sender in the top of the spider. I drilled a hole and used Hysol to glue in a threaded insert.
Scott
--- On Sun, 4/18/10, CLEMWEHNER <clemwehner(at)sbcglobal.net> wrote:
Subject: water temp sender location?
Date: Sunday, April 18, 2010, 9:19 PM
KF friends,
Clem
Oklahoma
KFIV-912
| Quote: | | _-========================nk" href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matrl="nofollow" target="_blank" href="http://forums.matronics.com">http:======================== |
| [quote][b]
lcfitt(at)sbcglobal.net Guest
Posted: Mon Apr 19, 2010 7:04 am Post subject: water temp sender location? |
Clem,
I am just about there on my new project and the installation manual calls for a CHT sender fitted to 10mm tapped holes on cylinders 2 or 3. you will find these facing down on those cylinders. Some have also installed some type of actual coolant temp gauges. I chose to go with the factory (Rotax) recommendation and used the tapped holes in the heads.
Lowell
Sent: Sunday, April 18, 2010 9:19 PM
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
KF friends,
Clem
Oklahoma
KFIV-912
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
