Prop Pitch Controller
PostPosted: Mon Apr 19, 2010 6:52 am    Post subject: Prop Pitch Controller Reply with quote
I've sketched a current limiter circuit and posted it
at:
http://aeroelectric.com/Pictures/Schematics/PropPitchController.pdf
The parts are available from http://digikey.com and the bill of
materials is about $10.
Under normal operations, the big N-fet transistor is turned on
hard (under 3 milliohms). Combined wit the 0.1 ohm resistor
in series will contribute less than 1/2 volt drop to normal
motor operating voltage. Gate drive comes though the LED/2.2K
resistor string from +14v.
When the motor hits the stop and stalls, current will rise
to the point where the 2N3904 gets turned on by voltage drop
across the .1 ohm resistor. The transistor pulls down on a
2.2K resistor causing the LED to light up and simultaneously
starving the N-fet for gate drive. The circuit will limit
total current to some value on the order of 6A thus preventing
a trip of the circuit breaker.
The N-fet needs to be on a heat sink suited for up to say
5 seconds of delayed turn-off after the motor hits the
stop. This needn't be much. You could build this assembly
on say 6 sq inches of .062 or thicker aluminum. It might
have a right-angle bend along one edge for a mounting
flange. The fet needs to be isolated from the heatsink
with a suitable insulating washer.
During stall-time, the N-fet is dumping about 14v x 6a
or 80 watts of heat. Okay on small heat sink for a few
seconds. There is no protective feature that would prevent the
n-fet from getting smoked if someone holds the switch
too long while the motor is jammed against the stop. With
a few more components, we can probably add time delay
feature that deprives the n-fet of gate drive a few
seconds after the stop is reached. I suspect you won't
need it.
etienne.phillips(at)gmail
PostPosted: Mon Apr 19, 2010 9:47 am    Post subject: Prop Pitch Controller Reply with quote
at:
Hi Bob, and everyone else following this thread...
I have an even simpler solution, possibly costing significantly less, using the hotly debated poly-fuse. Simply put a 6A or 7A one in series with the motor, with an LED+resistor across it. When the fuse trips, the LED is energised... In it's normal state, all the current travels through the low impedance fuse, and 'none' through the LED+resistor path. No heatsink required! However, there is the problem of securing everything and making sure vibration doesn't age the soldered joints prematurely.
Comments?
Etienne
dennis.glaeser(at)hp.com
PostPosted: Mon Apr 19, 2010 12:26 pm    Post subject: Prop Pitch Controller Reply with quote
Thanks Bob!
Now a few questions:
Does the current limiting characteristic you mention literally limit the current to the pitch motor? My guess is it does (at least somewhat), which is why the N-fet becomes a cabin heater.
I'm thinking that the electrical paths from the switch to the N-fet, and path from the N-fet to the ALSRJ resistor to ground need to be capable of 10A, but the other wiring will see much less.
How would I 'adjust for desired limit' on the ALSRJ resistor to go up to say 8A? How did you calculate or estimate that value? How sensitive would you anticipate that to be?
The reason I ask is that the load on the motor does increase as the pitch on the blades approach the high (and low) pitch limits, before the mechanical stop is reached. The mechanism is literally twisting composite blades, they don't rotate in bearings like 'regular' adjustable blades. I may have to adjust the current limit to be sure I can get the blades close enough to the pitch limits for my purposes. My rough measurement of current (reading a clamp on meter) indicates a pretty good knee in the curve at around 8A. 6A may be close enough, only testing will tell.
Finally, how would you compare this circuit to the reed switch approach that Joe Gores proposed, from a standpoint of repeatability of sensing the target amperage, and the ability to make adjustments to get to the desired target (number of winds and wire size selection)?
As usual, I'm awed by, and grateful for, your generosity of time and talent.
Dennis
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Date: Mon Apr 19 - 7:52 AM
at:
raymondj(at)frontiernet.n
PostPosted: Mon Apr 19, 2010 12:43 pm    Post subject: Prop Pitch Controller Reply with quote
Hi Bob,
Related question. How is the amount of heat sink area calculated? I
assume it is based on the amount of energy converted to heat. Where can
I find the info to determine what size heat sink is required. Does the
electrically insulating material also thermally insulate the component
and affect the design of the heat sink?
I'm not in any hurry for this info. Just came to mind when I read the email.
Raymond Julian
Kettle River, MN.
<nuckolls.bob(at)aeroelectric.com>
at:
need it.
