Threaded Gas Filler Neck Sealer
mountain4don(at)yahoo.com
PostPosted: Tue Jan 10, 2006 10:41 am    Post subject: Threaded Gas Filler Neck Sealer Reply with quote
I am getting ready to rivet up the top skin on my 601 XL wing, and wonder what to use as a sealer on the gas tank screw in filler neck cap threads. I am planning to rivet the top and nose skins on, then put some sort of sealer on the gas tank internal threads and on the screw in gas cap piece, and screw it in tight against the nose skin. But I am not sure what to buy, or what not to buy for this application. It probably needs to be something that is semi-ridged when set up, and gasoline proof of course. And won't leak. The filler neck appears to just screw in until it contacts the skin, and not all the way down to some sort of mating flare or something that would seal it up.
