		jrgowing(at)bigpond.net.a Guest
				 Posted: Sun Apr 18, 2010 3:52 pm    Post subject: Fuel Cap stuck on |
				I had noticed that the cap sometimes was caught and would  not come off - but a few more tries had always got it to come free  -
  But his morning it seems seriously stuck so I would  appreciate advice from those who may have "done it and got  it".........
  JR (Bob) Gowing Kit 327 in Oz -
  not finished and a lot more to do  yet......
 I am using the Free version of SPAMfighter.We are a community of 7 million users fighting spam.SPAMfighter hs not have this message.    [quote][b]
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		kevinmarie(at)blueyonder. Guest
				 Posted: Sun Apr 18, 2010 9:43 pm    Post subject: Fuel Cap stuck on |
				Hi
 My fuel cap was fine I then lost it!!! Don't ask.
 I put a replacement cap on and it has stuck ever since I have to use a
 screwdriver as a lever to prise it off.
 Kevin
 G-ODJG
 Tri gear 912ULS
 [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of JR Gowing
 Sent: 19 April 2010 00:50
 Subject: Fuel Cap stuck on
   _____
		pete(at)lawless.info Guest
				 Posted: Sun Apr 18, 2010 11:34 pm    Post subject: Fuel Cap stuck on |
				Kevin
 I also lost my original - again don't ask!
 My replacement behaved just as yours is doing.  We eventually noticed that
 the lugs that pop out to lock it in place were slightly protruding even when
 open and a couple of minutes with a file solved the problem.
 Pete
				 Posted: Mon Apr 19, 2010 12:45 am    Post subject: Fuel Cap stuck on |
				Thank you Kevin
  but we ought to get a proper fix - maybe there is a  thinner seal for example.
  Maybe others will have more ideas!
  JR
  [quote]   ---
				I should have mentioned that I am in Austalia and  am supposed to tether the cap to the a/c because it is out of sight of the  pilot in his cockpit!
  JR Gowing in Oz - no. 327
  [quote]   ---
				 Posted: Mon Apr 19, 2010 5:09 pm    Post subject: Fuel Cap stuck on |
				Thank you Pete!
  This sounds like the answer for a lot of us!
  I will look at this one carefully when I get the cap  off.
  Then I intend to fit a chain onto the centre of the cap on  its iside, and attach it onto a lug in the inlet; fibre washers  waiting.....
  JR (Bob) Gowing kit 327 in Oz
				 Posted: Wed Apr 21, 2010 2:02 am    Post subject: Fuel Cap stuck on |
				And for those interested, I slid a thin knife in the slot  and was able to remove the cap.
  When examined, you can see that there are  several edges on the cap side of the piece which enters the main body  set in the fuselage. I went around this several times filing a  bevel on the cap side of the edge. And this looks OK.
  Now to get my piece of chain to be anchored in  the inlet tube......
  JR - Kit 327
  I
  [quote]   ---
