Noah
Posted: Tue Apr 20, 2010 2:36 pm Post subject: S704-1 on Hot Side of Firewall? |
I requested the spec sheet for the S704-1 relay from B&C, and it is a Tyco T9A with an operating temp limit of 85C (185F). This seems a bit low for mounting in the engine compartment on the firewall. where I had been planning to mount it. I called B&C to ask them if they recommended mounting these in the engine compartment and the gentleman I spoke with was not sure - he recommended a post here.
Anybody know what the firewall temps can climb to?? Anybody mounted one of these firewall forward in an RV and had problems? Or had it last 2000 hours without issue??
_________________ Highest Regards,
Noah Forden
RV-7A
Rhode Island |
Posted: Tue Apr 20, 2010 7:30 pm Post subject: S704-1 on Hot Side of Firewall? |
At 05:36 PM 4/20/2010, you wrote:
It will be fine. These devices and their close
cousins are used under the hood of motor vehicles
and they're fine.
The various companies I've worked for have done
numerous studies of temperature under the cowl
and found that nothing gets really all that hot
as long as it's not exposed to direct infra-red
radiation from stacks (particularly turbochargers).
I've seen some RG battery cases melted because they
were too close to exhaust pipes.
Noah
Posted: Wed Apr 21, 2010 7:03 pm Post subject: Re: S704-1 on Hot Side of Firewall? |
Thanks Bob. Prior to your response, I moved the battery bus and E-bus relay south of the firewall on my schematic. I think I like that better anyway. Roughly the same number of wires transiting the firewall feed-thru. Does require a fusible link on the battery bus feed however.
Noah Forden
RV-7A
Rhode Island |
Posted: Thu Apr 22, 2010 6:22 am Post subject: S704-1 on Hot Side of Firewall? |
At 10:03 PM 4/21/2010, you wrote:
feed however.
. . . on the battery bus feed? Fusible links are
ROBUST protection on the order of ANL type current
limiters and should not be used in an always-hot feed
from a battery. Everything coming off the battery
should be a 7A or less fuse except where you need
a robust alternate path for the e-bus. In that case,
the battery bus fuse size goes up accordingly but the
e-bus relay becomes a "mini battery contactor" for
the e-bus . . . and should be as close as practical
to the battery bus.
