n10pg(at)neo.rr.com Guest
Posted: Thu Apr 20, 2006 12:28 pm Post subject: NSI Ignition Isolation Unit |
Hello NSI Subaru Drivers:
You may recall my e-mail post of 17 Feb. 06, in which I advised that subject
ignition isolation units are no longer available from NSI. Since then I have
been unable to find anybody that could make such a unit.
Therefore I was forced to research and develop such a unit on my own. The
attached picture shows the result. Dimensionally my unit is identical to
NSI's. I use the same plastics and composits as used by NSI. The brass posts
in my unit are Mil-spec Nickel-Tin plated for corrosion resistance and
improved conductivity. My unit also has a composit bottom plate for better
isolation of the internal high voltage electrical components from the
grounded metal mounting plate. I have made two units and installed them in
N10PG. They perform flawlessly. It may be of interest that each unit
consists of 24 purchased components plus 15 machined components.
I am prepared to manufacture one batch of additional units at a cost of $
450.00 each. Please let me know via e-mail by no later than 30 April '06 if
you want me to build one or more units for you
Please keep in mind that there is no alternative to having two properly
functioning ignition isolation modules when flying the NSI Subaru with two
independent electronic ignition systems. My experience to date: I have
replaced four failed NSI-manufactured isolation units in 1,000 hrs of
operation in N10PG.
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
Michael Logan
Posted: Thu Apr 20, 2006 3:21 pm Post subject: NSI Ignition Isolation Unit |
Peter,
As you have discovered, the isolation units are the weak single point
failure in the dual ignition system. I wish there was a better way. I have
not heard of anyone having a failure of any other part of the ignition.
By the way, is that $450 for the set?
Mike Logan
_________________ Mike Logan
Fredericksburg, VA |
Posted: Thu Apr 20, 2006 3:42 pm Post subject: NSI Ignition Isolation Unit |
Hello Mike:
No, each.
Peter
szakreski(at)shaw.ca Guest
Posted: Fri Apr 21, 2006 5:18 pm Post subject: NSI Ignition Isolation Unit |
Peter
Here's a thought:
Would you consider organizing a cooperative effort whereby we get some
number of people (say 20 people) to send you $200, and you make as many as
you can for the $4000 and hold them in stock. You could then sell them for
$450 to the stakeholders for as long as they lasted. In other words, the
$200 gives the stakeholders the peace of mind they have access to the
modules if needed.
If you sell all the modules, you have the money to go out and make a bunch
more.
If you or nobody else wanted to, I would volunteer to hold them in my
companies Parts Store as parts inventory if you didn't want to.
Some details still to figure out, but you get my drift.
SteveZ
Calgary
Posted: Sun Apr 23, 2006 4:03 pm Post subject: NSI Ignition Isolation Unit |
caseclosed66(at)hotmail.c Guest
Posted: Mon Apr 24, 2006 4:39 am Post subject: NSI Ignition Isolation Unit |
Hi Guys,
If it would help I an founder / President of an electronics manufacturing
facility. My facility could bang out as many as you need, I would be
willing to build, stock and ship any units you need.
If you are interested Peter, let me know.
greg(at)case-assembly.com
Posted: Mon Apr 24, 2006 5:12 am Post subject: NSI Ignition Isolation Unit |
Hello Greg:
Where were you when I was crying for help? Too late now. I have spent
hundreds if not thousands of dollars to research and made my own and am
willing to make more for anybody that needs them.
Peter
