Kelly McMullen
Posted: Thu May 13, 2010 1:31 pm Post subject: Andair Valves Redux |
I know there has been a fair amount of discussion in the past as to
location to mount the Andair, whether or not to use an extension.
Being at that point in my build, it appears to me that mounting the
valve flush with the top of the panel avoids the extension issue,
requires a few extra bends in fuel lines to make room for heater duct,
and puts heat right under the valve. On the other hand, it also seems
to put a large upward loop in the fuel circuit. It appears to me, not
having gone beyond this point and not knowing other pitfalls, that
using the full 12" extension would minimize the uphill direction of
fuel flow, allow heater duct to go above the valve and fuel lines,
while shortening the fuel lines between the entry to the tunnel and
the fuel filter. I have the newer "B" variety valve, so no
customization needed on the extension. What have others experienced in
delay time ordering direct from Andair? Wonder why Van's doesn't offer
the extension. I note that Van's valve mount is something like .060
aluminum. I have some .040 that would be handy to use, probably with
alu. angle, which seems like it ought to be plenty strong, or just
move Van's mount lower in the tunnel and make a plate to go on top of
it to accommodate the Andair configuration.
Kelly
#40866
Fuselage
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu May 13, 2010 1:43 pm Post subject: Andair Valves Redux |
We ordered a few things from Andair about 6 months ago including an extension kit. I was pleasantly surprised by how quickly they arrived. I don't think it was much more than a week.
I ended up just emailing my order because the web site order choked when I tried to check out. I got a response right away.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Thu, May 13, 2010 at 2:26 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
Kelly
#40866
Fuselage
http://forums.matronics.com
le, List Admin.
Tim Olson
Posted: Thu May 13, 2010 1:53 pm Post subject: Andair Valves Redux |
You see the light!
Good redux!
On May 13, 2010, at 4:26 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
Kelly
#40866
Fuselage
jdriggs49(at)msn.com Guest
Posted: Thu May 13, 2010 6:05 pm Post subject: Andair Valves Redux |
I've ordered from them several times lately on their web site and always got the stuff in less than a week. It used to be longer and the web ordering was terrible. My experience now has been seamless.
Date: Thu, 13 May 2010 14:26:53 -0700
| Quote: | Subject: Andair Valves Redux
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com>
Kelly
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. |
